Fuel gauge testing
Old Jul 12, 2017 | 09:10 AM
Connecticut Calvin's Avatar
Connecticut Calvin
Fuel gauge testing
Yes, you all should be able to tell I'm working out a few bugs. I have another one. How do I test my fuel gauge and my sending unit?
The gauge is brand new from Macs. The sending unit was included in the used '56 tank I got second hand. All is now installed but the gauge doesn't work. When I turn on the ignition it pegs at full and stays there. It goes back to empty when I turn the key off but it takes a while. I know for a fact I only have a few gallons in the tank.
I recall a thread I saw some time ago that showed the process but I can't find it.
Thoughts?
Old Jul 12, 2017 | 09:49 AM
Indybeer's Avatar
Indybeer
here are a couple links that should help
https://www.ford-trucks.com/forums/979251-fuel-gauge-doesnt-work.html
https://www.ford-trucks.com/forums/1...t-working.html
Old Jul 12, 2017 | 10:11 AM
Connecticut Calvin
That helps! I'll go through the check list and report back.
Old Jul 15, 2017 | 10:34 PM
BTclassics's Avatar
BTclassics
I am also having a problem with a new fuel gauge and sending unit from MidFifty. From my testing efforts, if your needle is pegged at full, the sending unit wire might being grounded out. To fully test, need to read the ohm readings coming from the sending unit.
My problem is that the gauge was always reading half. I got another new gauge and this one is always reading quarter tank (after I filled the tank). My sending unit was tested before going in and seemed to be ok. I'm still not sure what the problem is. I have an extra gauge and sending unit to hopefully figure it out. If I wanted a non-working gauge, I would have avoided all the time and expense and just left the original one in it!
Old Jul 15, 2017 | 11:21 PM
yosemite98's Avatar
yosemite98
I got a new sending unit from LMC Truck. It didn't seem to be working. But I took it out and tested with an Ohm meter. The resistance was changing when the float was moved up and down.
So, I figured it just wasn't calibrated correctly. I bent the wire with the float on it way down, almost vertical. Now, if there's ANY fuel in there it lifts up. When I have 7 gallons in there now it reads about 1/10 of a tank, but at least now I can tell when I need to get gas.
I think these things just aren't made correctly, as many others have had similar problems. I do know it matters if you're running 6 volt (I am) or 12 volt.
Old Jul 16, 2017 | 09:55 PM
BTclassics's Avatar
BTclassics
I'm running 12V. I wouldn't mind if the calibration was slightly off. But with all new parts and it reads half full or quarter tank (depending on gauge) all the time. Very frustrating!
Old Jul 16, 2017 | 11:01 PM
yosemite98's Avatar
yosemite98
If you're running a 6 volt sender with 12 volt it probably won't work.... and vice versa. Voltage is related to current (I) and resistance (R) via V = I*R. I don't know what the gauge is actually reading, but based on the equation the resistance OR the current would have to be 2x the value for a 12V system vs 6V system and therefore the gauge would not read correctly (if at all) if mismatching 6/12 sender.
Old Jul 16, 2017 | 11:05 PM
BTclassics's Avatar
BTclassics
Both the sender and gauge were supposed to be 12V. Is there any way to tell on the reproduction gauge if it is 12V or 6V?
Old Jul 17, 2017 | 07:17 AM
o7i's Avatar
o7i
Hi
I recently had exactly the same issue. A brand new fuel sender, the original (6v) gauge and I have converted the electrics to 12v. If you bought the voltage reducers that are for sale on macs/lmc then you have to create little adapter wires as the reducer needs to wire the wrong way round. I'll try and dig out some pictures of the back of my dash if it would help you but the stud on the reducer needs to go to the stud on the gauge and then you have two female connections between the sender wire and the reducer.
I think the senders aren't specific for 12v or 6v systems but you need to ensure the gauge only sees a maximum 6v and, as the sender comes after the gauge (at least in my system) the sender also just sees 6v.
Hope this helps? Let me know if it's a bit messy as I've written it in a bit of a rush
Old Jul 17, 2017 | 10:10 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Originally Posted by o7i
I recently had exactly the same issue. A brand new fuel sender, the original (6v) gauge and I have converted the electrics to 12v. If you bought the voltage reducers that are for sale on macs/lmc then you have to create little adapter wires as the reducer needs to wire the wrong way round. ...
Not sure what you mean here. The Hot (+) from the reducer goes to the Hot (formerly [-]) post on the gauges, which is a metal strip connecting all the Hot sides of the gauges. The sender wire stays on the same post as before.
Old Jul 18, 2017 | 07:10 AM
o7i's Avatar
o7i
I was told a few times that you needed a reducer per gauge. As the metal strips connect all the gauges together, the only place I could put the 3 reducers was on the sender side of the gauge, which means a bit of difficulty in the wiring. Of course I could be completely wrong but it seems to be working
Old Jul 18, 2017 | 08:14 PM
BTclassics's Avatar
BTclassics
Do you need to use a reducer if you use the 12V kit from MidFifty?
(Sorry for hijacking. How did you make out Calvin?)
Old Jul 21, 2017 | 07:19 PM
BTclassics's Avatar
BTclassics
I decided to do a bench test with just the gauge, the sending unit and a battery. Hooked it all up and the gauge reads "full" until the sending unit lever is pushed all the way down (empty) and the gauge reads around "3/4". Since the bench test isn't working correctly, I'm think I should try a reducer.
What type of reducer are people using for the fuel gauge?
Old Jul 21, 2017 | 08:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm surprised that works. If you are using the Runtz regulators, or the LM7806's, yes you need one per gauge. Usually the metal strips are removed and the reg's put in the power supply to each gauge. With the reg in the sender, it seems like the regulator would be trying to regulate a voltage already reduced by the resistance in the dash gauge. In other words, it might make the gauge read the same no matter what.
Old Jul 22, 2017 | 08:39 PM
BTclassics's Avatar
BTclassics
I'm lost. I guess I will start a new thread as it is getting confusing between 6v and 12v systems. Hopefully Calvin has his working!
Thanks.
elkarcher1716
Nov 24, 2015 09:38 PM
carbs & chrome
May 16, 2015 09:16 AM
thatsrealnice
Aug 18, 2014 02:33 PM
Luch
Mar 11, 2013 09:52 AM
