I have a 2013 f150 & the fuel pump relay fuse burnt out. I unhooked the battery cable "wasnt thinking" & took the fuse out & replaced it. Now my truck wont get over 3000 rpms & is driving like i got bad fuel or something. & now its throwing codes about my trac & i dont know why. Just from unhooking the battery cable & hooking it back up. Have any of yall encountered this or have an idea of what it is??
Ya i saw the thread about that and ordered the kit. I dont know what could have made it burn other then to much current for the fuse but i mean why would ford do that if it wasnt enough?? And as far as the truck running bad i know its a red flag i just dont know what the flag is i was kind of hoping this happend before & someone would know what it is. The truck is still under warranty but i dont know if taking it in would fix the problem or if they would just put a bandaid on it for it to happen again. I thought by unhooking the battery it shorted something maybe but i dont know why that would happen i mean you are suppose to be able to disconnect the battery and reconnect it so i dont know
My local ASE Certified mechanic shop is aware of the TSB. He says he services hundreds of F150s and has not seen this fuse problem yet. I am not saying it hasn't happened, but its not all that common or Ford would have put out a recall.
