Engine trouble
Old Jul 11, 2017 | 07:11 PM
Chris Mercer's Avatar
Chris Mercer
Engine trouble
I have a 2013 f150 & the fuel pump relay fuse burnt out. I unhooked the battery cable "wasnt thinking" & took the fuse out & replaced it. Now my truck wont get over 3000 rpms & is driving like i got bad fuel or something. & now its throwing codes about my trac & i dont know why. Just from unhooking the battery cable & hooking it back up. Have any of yall encountered this or have an idea of what it is??
Old Jul 11, 2017 | 09:40 PM
zxwut?'s Avatar
zxwut?
Have you looked into why the fuse blew in the first place? The truck running like crap right after replacing the fuse waves a big red flag to me.
Old Jul 11, 2017 | 10:03 PM
2jhanna's Avatar
2jhanna
The fuse burning is a very common problem on our F150s and there is a TSB on the subject and a very long thread here.
To do the fuse mod/TSB you have to remove the battery cable. I done the TSB mod myself with no problems.
My guess is that there is something else going on.
Old Jul 11, 2017 | 10:05 PM
2jhanna's Avatar
2jhanna
Thread for you if you're not aware of F27 issue.
https://www.ford-trucks.com/forums/1...pump-fuse.html
Old Jul 11, 2017 | 10:12 PM
zxwut?'s Avatar
zxwut?
Thank you.
Old Jul 11, 2017 | 10:32 PM
Chris Mercer
Ya i saw the thread about that and ordered the kit. I dont know what could have made it burn other then to much current for the fuse but i mean why would ford do that if it wasnt enough?? And as far as the truck running bad i know its a red flag i just dont know what the flag is i was kind of hoping this happend before & someone would know what it is. The truck is still under warranty but i dont know if taking it in would fix the problem or if they would just put a bandaid on it for it to happen again. I thought by unhooking the battery it shorted something maybe but i dont know why that would happen i mean you are suppose to be able to disconnect the battery and reconnect it so i dont know
Old Jul 12, 2017 | 08:16 PM
zxwut?'s Avatar
zxwut?
I agree; you should be just fine disconnecting and reconnecting the battery.
As for the excessive current, I don't believe Ford would be doing it on purpose. It doesn't make much business sense.
Old Jul 14, 2017 | 10:38 AM
SBV45's Avatar
SBV45
My local ASE Certified mechanic shop is aware of the TSB. He says he services hundreds of F150s and has not seen this fuse problem yet. I am not saying it hasn't happened, but its not all that common or Ford would have put out a recall.
gjamerson
Oct 18, 2025 06:47 PM
Snugsparkplug garage
Nov 22, 2017 08:24 PM
Fefanatic
2015 + Expedition & Navigator
Nov 16, 2017 08:58 AM
5851a
All Things Towing
Aug 7, 2016 05:14 PM
