Sponsored by: Real Truck
Dash Cam Windshield Mounting
Old Jul 11, 2017 | 06:59 PM
Ginther's Avatar
Ginther
I'm wanting to mount a dash cam up high on my windshield with 3M VHB tape.
Anyone ever used mounting tape on the black dots at the top of the windshield?
If so, Did it stick as good as it would to the area without dots?
Was it possible to remove the tape later without ruining the dots?
Borrowed image from the interwebs....
Old Jul 11, 2017 | 07:11 PM
Trophy_23's Avatar
Trophy_23
I just installed my Viofo A119S with gps mount and I stuck to top of the adhesive right below the dots on pass. side of the mirror. It is perfect, it blends in with the mirror from outside and you can't even see it from the drivers seat unless you duck down a bit. I ran the hard wire kit up next to the mirror wiring and along the headliner, down the A pillar and under the dash. It is very clean.
Old Jul 12, 2017 | 07:18 AM
Ginther's Avatar
Ginther
That's a good location too, I was just wanting to mount it a little higher.
I'm also curious if my toll tag would work thru the dots.
Old Jul 12, 2017 | 10:03 AM
Trophy_23's Avatar
Trophy_23
I wanted to go a bit higher also but didn't want to rip my dots off. Though with the shape of the camera it is almost mounted as high as you'd want to go because you have to slide it up if you want to remove it from the gps mount. Much higher and you'd have to move the mirror to get it off. So your dots are on the surface of the glass like mine? My buddy has a 2012 F150 and his is inside the glass leaving a smooth surface which is nice. I thought maybe they had changed it in all the newer trucks.
No idea about the toll tag but I would think it might if it works like ours here which is a radio signal.
Old Jul 12, 2017 | 11:52 AM
Ginther's Avatar
Ginther
My dots are on the surface. You can feel them.
From what I've learned so far they are baked INTO the glass. I've read elsewhere that they are super hard and nearly impossible to remove.
The challenge will be getting the tape to stick to the top of the dots and down and around them all the way to the glass. Thicker tape would probably help in that case.
I'm going to order a new toll tag and put it behind the dots and see if it works. Replacements are free as long as I sign up for auto billing... so why not try it out lol!
ForeverFixing
Feb 5, 2018 06:28 PM
shortride
General Automotive Discussion
Jun 9, 2017 01:02 PM
co425
May 18, 2011 02:02 PM
zooom
Paint & Bodywork
Aug 25, 2007 05:51 PM
trakman
31
Dec 29, 2006 10:12 PM
