Lost forward and reverse gears
Old Jul 11, 2017 | 02:00 PM
nick_ct_203's Avatar
nick_ct_203
99 expedition 5.4. I recently swapped engines cause the one I had was having issues and since I had one in the garage I swapped it in. Since that I have not been able to get this truck to move. I had to replace the flexplate cause it was cracked. You put it in gear and reverse the he'll outta it to move a few inches. Doesn't matter forward or reverse. The pump is good I checked that, couldn't tell if torque converter was good. Can anyone help me out with what it might be. It moved fine before the engine swapped but now nothing. Could the converter have been going bad and by taking it out and putting it back in it's completely shot now?
Old Jul 12, 2017 | 07:09 AM
projectSHO89's Avatar
projectSHO89
Will it move forward with the shift lever in manual 2nd?
Old Jul 12, 2017 | 08:51 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How did you check the pump? What pressure is at the test port in each PRND21 position at idle?
Framer7
2004 - 2008 F150
Aug 8, 2016 08:12 PM
chrison600
Oct 11, 2012 08:27 PM
gravel pit camper
2004 - 2008 F150
Oct 12, 2011 10:32 AM
firefighter15
Mar 8, 2011 07:58 PM
60RatRod
Dec 16, 2009 05:45 AM
