what is this wire?
Old Jul 11, 2017 | 05:28 AM
crawlin-kingsnake's Avatar
crawlin-kingsnake
what is this wire?
Hi guys,
I´m overe here in Germany and new to the forum but been a constant reader since two years.
Bought a 1984 F250 Supercab 4x4 6.9 IDI Banks turbocharged.
I´m in the restoration process right now and found an unconnected yellow cable coming from the harness on the driver´s side underneath the brake booster. When I had the dash all out I was able to trace it to somewhere to the ignition switch, but not sure since I did not splice the harness.
The truck hauled a camper and trailer once. I´m thinking that maybe it was for one of these purposes since there´s a smaller red cable DIYed to the yellow one, looking like an extension cable going nowhere (about 1 foot long).
Any help appreciated and thanks in advance.
Oh, and instrument cluster/dash illumination doesn´t work though digital clock does. New headlight switch installed. And thoughts? Connector C208 is good and contacts clean.
Old Jul 11, 2017 | 05:59 AM
Franklin2's Avatar
Franklin2
More than likely that is power for a trailer. Is it hot all the time? Here is a link to a 86 model.
Trailer Option - ???Gary's Garagemahal
On your dash lights, check the fuse. The fuse will only have power if the headlights are on.
Old Jul 11, 2017 | 06:44 AM
crawlin-kingsnake
HI, thanks.
Allright, sounds plausible. I´ll check.
Cluster illum.:
Checked the shop manual. That says if park lights work then it´s not the fuse. Park lights are ok. I´ll check the fuse again anyway.
Old Jul 11, 2017 | 06:49 AM
Franklin2's Avatar
Franklin2
Originally Posted by crawlin-kingsnake
Cluster illum.:
That's not correct. The shop manual has been known to have typos. Here's the circuit, You can see it has it's own fuse.
Instrument Illumination - ???Gary's Garagemahal
The park lamp circuit fuse does feed this circuit, but this circuit has it's own fuse downstream. So if the park lamp circuit fuse was blown, this circuit would not work. But this illumination fuse can blow and the park lights still work.
Ethan Samora
1978 - 1996 Big Bronco
Sep 14, 2015 11:44 PM
SidWell
Electrical Systems/Wiring
Aug 20, 2015 01:48 PM
Moonshae
Escape & Escape Hybrid
Mar 13, 2011 12:37 PM
isaz
Dec 22, 2003 11:36 AM
Tacocaster
Jul 20, 2003 07:56 PM
