Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape Hybrid Tail Lamp problem
Old Mar 12, 2011 | 09:38 AM
Moonshae's Avatar
Moonshae
Hi All,
My 2009 Escape Hybrid's tail lights are out, and after checking the manual, none of the fuses specifies control of them. Does anyone know which fuse I need to replace, or what else could be wrong? My brake lights work just fine, as well as my headlights.
Thanks!
Old Mar 13, 2011 | 08:30 AM
wptski's Avatar
wptski
Originally Posted by Moonshae
Hi All,
Thanks!
Try looking at the fuse listed as "park lamps".
Old Mar 13, 2011 | 09:45 AM
scott91370's Avatar
scott91370
Do your dash lights work? You kmay also look at that fuse.
And, just because the fuse looks good does not mean it is. They can blow and the area you can see will look like it is ok but the end will be gone. Replace it anyway.
Old Mar 13, 2011 | 12:37 PM
wptski's Avatar
wptski
The top of the fuse has a bit of exposed metal contact at each end. If you have a volt meter or 12V tester, you should have 12V from both points to ground.
250andEX
Apr 27, 2017 06:03 PM
accent2010
Feb 20, 2017 03:07 PM
Avanti
Ford Truck Parts for Sale
Feb 9, 2017 02:40 PM
laser1USA
Dec 26, 2016 09:48 PM
BigHinAK
Apr 24, 2011 11:14 AM
