It does take some getting use to the mirrors on this thing. Only a little over 100 miles. Has anyone adjusted the bottom part of the mirror (tow mirror)?
I thought it a bit odd that the larger top mirror is power adjustable and not the bottom. I'm sure there is a reason other than manufacturing cost. Maybe Ford is saving it for a future model.
Maybe. Being convex, it's not nearly as sensitive to seating position, so maybe that's it too.
Yes, it's on a pivot. It'll go any way you want.
If it were power adjustable, I would think that people would get confused with that many buttons. (Not like there's not enough of them the way it is)
I knew it was not powered, just not if they moved. Thanks, fun figuring stuff out. I am able to use my keyfob to open the front windows now! LOL Got the delay set for the camera......
I guess that could be a possibility. It would only be an inconvenience if someone came along and moved it on purpose and you didn't notice it until you discovered you can't see the traffic out of that particular mirror. That's when you appreciate a power adjustable mirror.
