TPMS?
Old Jul 6, 2017 | 10:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
TPMS?
Old Jul 6, 2017 | 11:02 PM
Tricon's Avatar
Tricon
You can change the tire pressure ranges to whatever you want with FORscan or a dealer trip. Takes 5 minutes.
Old Jul 7, 2017 | 05:00 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Well that's good to know. Is there an upper limit? Say I have the dealer set it to 25psi...will it be unhappy when I run 50-80psi?
Old Jul 7, 2017 | 07:48 AM
crewzer's Avatar
crewzer
Lightbulb
Originally Posted by ATC Crazy
... Secondly, can I order a F250 with a GVWR higher than 10k, or do I need to step up to the F350 for that?...
Highest official GVWR for the 2017 F250 is 10K, no matter what configuration. If you want/need more, then you have you go to an F350 SRW (officially up to 11.5K depending on configuration).
HTH,
Jim / crewzer
Old Jul 7, 2017 | 09:49 AM
troverman's Avatar
troverman
TPMS simply reports the tire pressure to a module in the vehicle. It sets off the alarm if the reported pressure is lower than the set threshold.
The Ford also displays actual tire pressure readings. Here's what the alarm looks like when you have a low pressure issue...this is a screenshot of my 2017 dually with leaking valve stems:
Old Jul 7, 2017 | 03:44 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thank you. My Dodge displays the pressure, but there is no warning or lights (dually) since above 10k GVWR. I run 70-75F and 50 in the rears.
Old Jul 7, 2017 | 04:16 PM
System's Avatar
System
Prolocutor
Most dealers won't do the change to the alert threshold due to liability. As said above, it can be done with the free Forscan program and an OBD2 adapter. Check out the Forscan Spreadsheet thread for details on this and a lot of other good changes you can make.
No 3/4 ton (250/2500) can be rated over 10k as they are limited by being a Class 2 truck on paper. They can be de-rated but the GVWR can't be increased. SRW 350 is the way to go if you want more GVWR. It rides about identical and costs pretty close to the same too.
Old Jul 7, 2017 | 04:40 PM
USSenator's Avatar
USSenator
Why would you not want a warning? Are you driving on sand dunes?
Old Jul 7, 2017 | 05:11 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Because I don't need to run 80psi on an empty truck 80% of the time. It rides like a brick and will wear the centers of the tires. Then with aftermarket wheels and larger tires, you can run even less pressure to make them wear even.
TPMS is another useless expense and maintenance/nagging item that is unneeded....no thanks to Ford/Firestone causing it to become law
Nanny-state crap that a lot of people don't want.
Old Jul 7, 2017 | 05:20 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah, I kinda figured that about the liability. I did glance through the spreadsheet thread. I think it's great that the program is available to the end user...can't do that with Ram. You gotta go to the dealership and hope the mechanic knows what you want done...and does it right without screwing up anything else. Then you have to PAY for it
Old Jul 8, 2017 | 08:31 AM
troverman's Avatar
troverman
I am against government intervention / requirements on most matters, but I disagree that TPMS is a waste. I really enjoy being able to see the pressures displayed, and I appreciate the warning that comes on automatically when a tire is low. Driving a dually, it would be difficult to notice a tire, particularly an inner tire, becoming soft.
Cabindweller
Jul 8, 2017 08:14 AM
bushpilot
May 10, 2017 10:06 AM
TrailerTrash
Aug 30, 2007 09:55 PM
Jim McCarty
Feb 21, 2006 06:08 AM
