Power Steering Lines
Old Jul 6, 2017 | 03:35 PM
pchelp's Avatar
pchelp
Need part numbers for new power steering lines, this power steering gearbox came off a 70-72 F100
Old Jul 6, 2017 | 04:10 PM
yellow truck's Avatar
yellow truck
I suggest you don't bother with part numbers and instead look up a hydraulic hose supplier in your area, and take in the old parts. I had some made for pretty small change.
Old Jul 6, 2017 | 04:12 PM
pchelp's Avatar
pchelp
Hmm, new thought about that. Will they need to know pressures?
Old Jul 6, 2017 | 04:15 PM
yellow truck
The guys I used knew what was what from the parts. It is all pretty standard and the PS pumps put out less pressure than most applications. They had every fitting I needed and the tool to press them together.
Load up on hose clamps while you are there, they sell ones that won't cut the hoses at the edge of the clamp, and ones that can take a lot more torque on the fitting.
Old Jul 7, 2017 | 08:45 AM
ultraranger's Avatar
ultraranger
I don't know what engine you have but, you can just go to NAPA and order the PS pressure and return hoses for your year model and engine.
Old Jul 7, 2017 | 09:24 AM
pchelp's Avatar
pchelp
Looks like the local Auto Zone has them in stock plus the cooler for less than $20 yeah bonus !
Old Jul 7, 2017 | 10:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by pchelp
Need part numbers for new power steering lines, this power steering gearbox came off a 70-72 F100.
What size is the engine?
Old Jul 7, 2017 | 10:31 AM
pchelp's Avatar
pchelp
It is in my 69 with a 390, I should also say this is not what came with the truck. The power steering gearbox and the pump came off a 72
Old Jul 7, 2017 | 11:09 AM
NumberDummy
It is in my 69 with a 390, I should also say this is not what came with the truck. The power steering gearbox and the pump came off a 72.
The Ford/Thompson P/S pump (has a steel reservoir) is the same 1967/77.
Ford/Saginaw P/S: 1969 F100/250 2WD & F350 from serial number D96,001; 1970/79 F100/250 2WD & F350.
D0TZ-3A719-A .. P/S Pressure Hose / Obsolete
1969 F100/250 2WD & F350 360/390 with Ford/Saginaw P/S; 1970/72 F100/250 2WD & F350 360/390.
FEYER FORD in Edenton NC has 1 = 252-482-2144.
MAINER FORD in Okarche OK has 1 = 405-263-7242.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
C9TZ-3A713-G .. P/S Return Hose / Obsolete
1969 F100/250 2WD & F350 240/300 I-6 & 360/390 with Ford/Saginaw P/S; 1970/72 F100/250 2WD & F350 240/300 I-6 & 360/390.
GREEN SALES CO. has 1.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
Old Jul 7, 2017 | 11:13 AM
pchelp's Avatar
pchelp
C9TZ-3A719-G .. P/S Return Hose / Obsolete
Thanks again Number
Old Jul 7, 2017 | 11:18 AM
NumberDummy
Thanks again Number
TYPO!
The P/S return hose is C9TZ-3A713-G not C9TZ-3A719-G
I edited the correct part number into post #9.
Old Jul 7, 2017 | 03:00 PM
pchelp's Avatar
pchelp
TYPO!
Ok thanks again Number
Coleton_henry
Dec 22, 2017 12:39 PM
Jesser02EX
May 5, 2015 09:15 PM
89danford
Feb 17, 2014 04:35 PM
safari1957
Jan 7, 2012 09:01 AM
dieingford
Mar 18, 2004 11:43 AM
