P/N request: power steering lines
Old May 5, 2015 | 04:54 PM
Jesser02EX's Avatar
Jesser02EX
As I prepare for my new motor, I'm working to replace old weak points. I'd like to replaced pressurized power steering lines. Does anyone have the right part numbers? Do I need both or just a particular one?
I'll put a new pump in too. I'm surprised mine hasn't fallen apart when I see how it is put together.
Old May 5, 2015 | 09:15 PM
brian42's Avatar
brian42
Veteran: Navy
My OEM ones lasted over 230K miles and then I replaced them with NAPA. My power steering blew out in the driveway one morning and they were the only ones with the pressure hose and line in stock (sometimes you got to go with what you can get in a pinch and the truck had to be back up that day). They lasted about 40K and now they're leaking. I don't have the OEM parts number since I used went NAPA. I am going to try the Gates ones next as I have had good luck with Gates products and they are considerably less expensive (just replaced my gearbox so my car jar $$$ is low). Again, don't know the part numbers but you can find them on www.rockauto.com.
pchelp
Jul 7, 2017 03:00 PM
89danford
Feb 17, 2014 04:35 PM
cam360
Sep 28, 2012 04:38 PM
billybird
Sep 18, 2004 07:15 PM
