Power Steering hoses
Old Jan 6, 2012 | 06:24 PM
safari1957's Avatar
safari1957
Happy new year to all. Well Methuselah is about to get a new lower steering shaft [flaming river FR1857-FD2S custom stainless steel], gear box and power steering pump [AGR 213678]. I am also replacing the lines. The Edelmann Stock number for Methuselah's power steering hoses are: 91847 & 71079. I am trying to find the equivelant in stainless steel. I know about March Performance braided steel lines, but you have to put fittings on one end - I would prefer to have both lines with fittings in place for both ends; like the aforementioned edelmann products. Anyone out in cyberFordland know anywhere I can find those lines in stainless steel? Thanks!
Old Jan 6, 2012 | 09:10 PM
Sw1tchfoot's Avatar
Sw1tchfoot
I can't really answer your question, but for the return line there is only one fitting anyway right? The other just slips on to the reservoir and uses a hose clamp?
Old Jan 6, 2012 | 11:40 PM
lavatan's Avatar
lavatan
The parts shop here in town can make compression fittings. Have you checked there to see if you can get a custom made hose?
Old Jan 7, 2012 | 08:21 AM
safari1957's Avatar
safari1957
Yes you are correct... What I want is stainless steel for the pre bent cooling lines and braided stainless for the rubber end of the return hose as well as the pressure line.
Old Jan 7, 2012 | 08:27 AM
safari1957's Avatar
safari1957
I could do that - but no one I know can fabricate the long pre-bent cooling line....that attached to the rubber hose.
Regards,
Kelly
Old Jan 7, 2012 | 09:01 AM
safari1957's Avatar
safari1957
Regards,
Kelly
I may have solved my problems - Classic Tube, Preformed Tubing
Looks like they will have what I need. waiting on
confirmation from the company.
Anyone ever use these guys???
Regards,
Kelly
pchelp
Jul 7, 2017 03:00 PM
mario9272
Feb 4, 2014 04:16 PM
1low50
Jan 18, 2008 11:03 AM
dieingford
Mar 18, 2004 11:43 AM
