No acceleration
Old Jul 5, 2017 | 08:41 PM
Fishing8107's Avatar
Fishing8107
No acceleration
I have a 02 f150 with the 5.4L vin "L". It is an automatic transmission and 4wheel drive. I bought it for 100 bucks and it sat for over 3 years. It would not crank or turn over at all. I put a starter on it. Cranks but no start. Replaced the fuel pump. Truck starts and runs. While still cold it runs ok. After it warms up the idle is still ok but sounds a little off. When I put it in gear the truck will hardly move. I replaced the fuel filter and MAF sensor. Still same issue. Tried the fuel pressure regulator. Still same issue. I am getting 35 psi fuel pressure at idle. When accelerator is pressed the pressure goes up to 40 psi. I checked the SES light and I have bank 1&2 lean codes. I removed all the old gas out of the tank and put in new gas before I even ran the engine. The truck is in great shape a side from the rocker panels. I appreciate any help I can get. Thanks.
Old Jul 6, 2017 | 10:14 AM
alloro's Avatar
alloro
Why are you focusing on the engine instead of the drivetrain or possible locked brakes?
Old Jul 6, 2017 | 11:51 AM
Fishing8107
I have driven the truck around in the yard. The brakes are not locked up. I inspected them before I attempted to drive it out on the road. As far as transmission goes. I'm not sure about that but I have felt it shift just in the yard and I didn't get any transmission codes.
Old Jul 7, 2017 | 05:10 AM
96f150's Avatar
96f150
...crazy question, but, can you move the throttle butterfly by hand under the hood?
Old Jul 9, 2017 | 10:57 AM
alloro's Avatar
alloro
Then if you want help you need to be accurate with the symptoms. In your last post you said you drove it around the yard but in your original post you said, "When I put it in gear the truck will hardly move". So which is it?
Old Jul 13, 2017 | 05:10 PM
enriched&beyound's Avatar
enriched&beyound
I guess I would be more interested in why it was parked so long to being with??
Trans going out?? engine maybe mot running correctly?? DO you have any back ground information? With modern vehicles it harder on them to sit extended periods then to drive them.
Jim98F150
1997 - 2003 F150
48
May 8, 2015 02:39 AM
LaReko
1997 - 2003 F150
Jan 13, 2013 10:55 PM
wm070779
Aug 15, 2010 10:00 AM
sdbiddle
Jul 18, 2009 08:36 AM
t_dickie
Oct 22, 2006 01:17 AM
