Sponsored by: Auxito
Fuel pressure regulator question
Old Jul 7, 2012 | 02:52 PM
LaReko's Avatar
LaReko
I have a 1999 F150 4.2L. Can someone tell me what the signs and symptoms are for a bad pressure regulator?
Old Jul 7, 2012 | 04:45 PM
Bluegrass 7's Avatar
Bluegrass 7
Only way to tell anything is test fuel pressure with a gage on the test port.
Engine at idle 30 to 45 psi.
Remove the vacuum hose, read 40 to 50 psi.
Engine shut down after test should hold pressure for 5 min at 30 to 40 psi.
Issues caused by too high or too low pressure are many and varied from rich running to lean fuel starvation.
These conditions set a number of codes depending on what and when the systerm detected an issue via the OX sensors.
A low pressure can be a faulty fuel pump or a plugged filter.
Long crank times could be the fuel pump.
I can't answer only to you general question so what problem are you having?
Good luck.
Old Jul 7, 2012 | 04:58 PM
LaReko's Avatar
LaReko
No codes Bluegrass. Every once in a while it lacks power and will shutter or have a slight miss on take off. Idles rough at times. No vac leaks. Throttle body is clean as a whistle and new IAC valve. New plugs and wires were installed just about an hour ago. I haven't test drove it yet but it seems to idle better. I thought maybe a plug or wire was breaking down under a load. I also changed the coil pack.
Old Jul 7, 2012 | 08:45 PM
steve(ill)'s Avatar
steve(ill)
If the regulator fails, gas leaks back to the tank and you have starting problems / lag. THe pressure should be maintained on the fuel rail for several hours. Put a gauge on the schrader valve, or just push the center pin after a few hours and see if pressure is good.
Old Jan 13, 2013 | 10:55 PM
jack armstrong's Avatar
jack armstrong
I have to turn key on for 2 mins before cranking so truck will start 2001 f 150 v8.
Keith Wells
Oct 5, 2020 03:21 PM
Enterprise Blue
3.8 & 4.2L V6
Mar 21, 2015 08:24 PM
XSleeper
Apr 29, 2014 01:42 PM
BURNSTOUGHFORD
1997 - 2003 F150
17
Mar 23, 2009 04:21 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
