Cab replacement thread
Old Jul 2, 2017 | 06:57 PM
Justin73supercamper's Avatar
Justin73supercamper
Well I have been threatening for a long time to replace my rusty cab on my 73 scs. After giving my step son my first replacement cab with stipulations that has yet to touch. I found this 78 cab for 50 bucks. Overall it is in good shape except for the right floor pan. Looks like the heater core leaked for a long time. And I found some pin holes on the left rear cab corner. And a small dent. I have a parts cab with perfect floors and cab corners so that's all free but my time too cut out. So if I decide to take tomorrow off work I'll start the repairs. My plan is to fix the cab corner floor pan and any thin metal I find. Replace all seals. Paint the inside to match my existing cab and have back together by September. So enough rambling here is some before pics of the new cab. I'll post more pics as I go.
The rusty floor pan. Going to take it out on top of the transmission tunnel ans across under the seat are
The good side
Parts cab right floor pan
Going to use a piece of this left side where the tank selector valve mounts. Replacement cab little bit thin there
Old Jul 3, 2017 | 07:45 AM
Jonnyuma's Avatar
Jonnyuma
We do love our recycling in OR, don't we.
Post as many pics as you can, Justin. I know I've got some of the same repairs as you in my future and I'd really like to see how you go about it using factory bits instead of buying patch panels new.
Good luck, I'm looking forward to seeing your work.
Old Jul 3, 2017 | 08:04 AM
Justin73supercamper
lol yeah I we do like recycling . In my case I'm cheap why buy something I already have. I will post pics. But I will do you one better. Since we have talked on the phone and you seem to be a good guy. I'll invite you over when I'm done so you can see in person. We don't like live that far apart. And I'll show you the steps I took.if you're interested
Old Jul 3, 2017 | 09:06 AM
Jonnyuma's Avatar
Jonnyuma
Absolutely, I'm in!
Old Jul 3, 2017 | 09:12 AM
Justin73supercamper
Absolutely, I'm in!
cool. I will give you a call when I get the pans in.
Old Jul 3, 2017 | 09:20 AM
Jonnyuma's Avatar
Jonnyuma
If Summit, UPS, and I all do our part, I should have new tires, wheels, and a 4 bbl on my 76 by then... I'll bring it. Or it will bring me, whatever, and I can show you it's problem areas.
Old Jul 3, 2017 | 09:23 AM
Justin73supercamper
that will be cool. I have had good luck and fast shipping with summit.
Old Jul 3, 2017 | 07:31 PM
Justin73supercamper
Got some work done today. Cut floor pan out of the parts truck. For it in the new cab , more fitting to do but should be able too weld tomorrow would tonight but I coated all the rust with rust killer going too let it cure tonight. Here's some pics Big a@& hole.Figured get all the thin metal
Setting replacement in for cutting
Test fittings
Old Jul 4, 2017 | 07:16 AM
Mac J's Avatar
Mac J
Subscribed
I need some motivation and confidence-building for some cab work as well.
Old Jul 15, 2017 | 05:24 PM
Justin73supercamper
I got the passenger side floors welded in today.I used 16 gauge stainless steel for the patches I had to make. Let those areas rust out again lol. Only reason I used it is because I had it laying around. I didn't grind the welds perfect flat figure why since I'm covering it it sound deadner mat and carpet. I will flip the cab on it's back so I can grind the under side and paint. Here is some pics
eb76adam
Jan 28, 2017 10:11 PM
reamer
Feb 15, 2016 03:58 PM
johnfin1
Apr 18, 2015 11:55 AM
Rossta86
42
Dec 14, 2010 12:11 AM
Blue Rebel
20
May 7, 2009 03:45 PM
