Cab swap progress thread
Old Apr 28, 2009 | 09:48 PM
Blue Rebel's Avatar
Blue Rebel
Hey guys, here is where ill post up pics i take of the progress on my cab swap. Here we go!
First, here is where i was at by lunch, all trim, door panels, and headliner out:
After lunch the seat and floor cover came out, and this is the first time i actually saw how bad my cab really was:
Pass floor pan:
Found this mouse nest under the kick panel, from the trucks days as a lawn ornament.
Pass side cab corner, w/ another mouse nest:
After removing the nest:
Heres the rear wall and window, look, my truck''''s growing!!
VVV Do you see pavement VVV
Drivers side cab corner
[imig]http://i26.photobucket.com/albums/c121/huston123_99/89%20Rusty%20Cab/HPIM0163.jpg?t=1240966353[/img]
And heres where its the worst, Driver side floor
Here is where the floorpan was seperating from the firewall. There was actually only about 3" of sheetmetal still holding the cab to the front left body mount.
So as you can see, just fixing my cab up really wasnt an option. Cant wait to get the new one on there, and be rid of all this rust!!
Old Apr 29, 2009 | 02:13 PM
Blue Rebel's Avatar
Blue Rebel
Aw no one thinks my stuffs interesting....
Old Apr 29, 2009 | 02:26 PM
94WhiteF250's Avatar
94WhiteF250
Wow I cant believe how bad she was... gonna be awesome to have a new cab on there, plus im sure an awesome learning experience. Do you have a cab already?
Old Apr 29, 2009 | 02:52 PM
1966Tbird's Avatar
1966Tbird
that's horrible lol i love that windsheild sticker i think it would be worth swapping windshields to the new cab
Old Apr 29, 2009 | 05:58 PM
aic's Avatar
aic
Gosh that makes me afraid to see what my cab looks like under the carpet. Good Luck!!
Old Apr 29, 2009 | 06:00 PM
1966Tbird's Avatar
1966Tbird
yeah i had 2 rust holes under the black trim on the pass. side but i fixed them with some fiberglass bondo and undercoating
blue rebel what are you going to do with your screen name? or are you just going to paint the new cab blue so you don't have to change your name lol
and what are you doing with the doors, i'm looking for a set that i can chop up to make some half doors for my truck
Old May 6, 2009 | 07:02 PM
Blue Rebel's Avatar
Blue Rebel
Hey guys, sorry i havnt posted, been bustin my butt tryin to get this all done.
Tried removing the windshield, but it cracked just as i got the first 1/2 peeled free.
Gonna keep the screen name,
Soon as i have enough money the trucks gonna get repainted back the original blue. I love that color, it sparkles so much when it looks nice
Gettin rid of the doors tomorrow, gotta let me know tonight if you want them or not, and how you can get them. Living at parents house, i got no where to store anything anymore. theyre yours free if you can get them.
More pics on the way NOW, just wanted to post this up before i started on my long post
Old May 6, 2009 | 07:18 PM
Jermafenser's Avatar
Jermafenser
Oh, that cab makes me want to barf...glad you're replacing it. Scrap it to offset some cost.
Old May 6, 2009 | 07:42 PM
Blue Rebel's Avatar
Blue Rebel
Here we go, gonna try and get these all in order, lol
Found this under the vinyl floor, thought it was kinda cool:
Here you can see my cab was actually growing green stuff! lol
The roof was dented and twisted too, even though far as i can remember no ones ever been up on it
ANOTHER mouse nest!!!
Dash is out
NEW CAB!!!
Look, almost no rust!!!
Pulling front clip off
Front clip off, start of a new day
There goes the cab, had to cut off 1 body bolt, other 3 came out surprisingly nice
off the truck
Love to do engine work now!!
Now we start puttin the 89 stuff into the 92 cab... bring on the HEADACHES!!!
89 Pedals into 92 cab
Found out the 2 cabs have different mounts for their pedal assemblys. Had to cut the one out of the 89, and weld it into the 92
89 mount
92 mount
on the 92 cab there is no hole for the dome light switch, had to drill and tap my own
had to cut a bit out of the 89 dash to get it into the 92 cab. not just the blue plastic either. underneith i had to trim out about 2" of the metal frame
Dont ask me why, but ford decided to move the upper seat belt mount 1". Gotta love the chits and giggles design changes
The window parts on the newer doors are different also, the crank rod sticks out farther. Heres my 89 door panel and 89 crank on the new 92 door
Throttle pedals changed also, here you can see my 89 pedal hooked up, with the 92 in the foreground. the 89 used small c channel, whereas the 92 used a bent flatstock for the brace. when i hooked everything up, the 92 pedal held my throttle open about 1/8"
Another shot of the 2 throttle pedals
Square hole, round plug? lol had to cut out the square hole, and caulk around the gap
Something that did fit nice, the 89 rear slider into the 92 cab
Buttoning up....
And ALL DONE!!!! (for the most part lol)
Old May 6, 2009 | 07:43 PM
Blue Rebel's Avatar
Blue Rebel
So what happened to the old cab, do you ask... well, first i tried the convertable idea
but then i figured mud would just get everywhere, so i ended up junking it
And here it is all loaded up, ready to hit the scrapyard tomorrow
Boy i gotta say, dogs really do know how to enjoy a nice sunny day! yes, i know we need to mow, but i had to get the cab outta the yard first!
As far as how things went... The cab itself bolted on real nice, 89 front clip bolted to it real nice, I did have to use the 89 cowl also. But with the interior, there were SO MANY little things that ALMOST fit. screw holes that ALMOST lined up. The HVAC ALMOST bolted right in. The dash ALMOST bolted right in. The trim panels ALMOST lined up w/ things. Honestly, if i had known how many little things were going to be different, i probably would have held out for an 89 cab. LOTS of little headaches, but definitly doable, long as you have a welder, cutting torch, and alot of liquid courage, lol. So, whaddya think?!
Old May 6, 2009 | 08:42 PM
Mrboylston's Avatar
Mrboylston
Nice job with the cab switch. Hey I like that front bumper of yours. Did you just weld up some plate? If so how thick did you use? And any idea what i weighs in at? Thanx
Old May 6, 2009 | 08:43 PM
dustybumpers's Avatar
dustybumpers
great job... you were right before, I had no Idea how much rust you had. lucky it diddn't fall off going down the road. congrats on a good job
Old May 6, 2009 | 08:47 PM
Jermafenser
It's amazing to see how much has changed in three years and a body style.
I really like the OTP news. That plant is still operational, and is running on paint fumes today!
How long did it take you to swap over and install everything? Looks like you did everything in one day!
Old May 6, 2009 | 08:48 PM
Blue Rebel's Avatar
Blue Rebel
no plate for the front bumper, thats C channel cut, bent, and diamond plate added to the top. Suckers gotta weigh about 200lbs. I could not lift it off the ground on my own
Old May 6, 2009 | 08:52 PM
Blue Rebel's Avatar
Blue Rebel
Speaking of old pics, heres a couple for comparison:
Three days after i pulled her out of a field, and got it running:
And as of today:
The swap took about 4 days of hard work to do, but i didnt work hard every day, so it took me about a week. And thats with no air tools, no torch, and working by myself for most of the time. Had 1 guy helping 3 days, but that was it.
