Sponsored by: Auxito
Ac oil when adding freon
Old Jul 2, 2017 | 04:21 PM
garyd's Avatar
garyd
I got a 2001 f150 leaking freon on the back of the compressor, can't afford to fix this summer. When I add freon should I get the freon with oil in to get oil in the system or just add regular can of freon, it took about 6 weeks before I need to add any.
Old Jul 2, 2017 | 05:18 PM
steve(ill)'s Avatar
steve(ill)
normally the oil stays inside the system... do you see dampness ? I would had just R134 4-5 different times as needed before I added any more oil.
Old Jul 2, 2017 | 05:55 PM
garyd's Avatar
garyd
The shop that added freon said some oil was running out the back of the compressor, can you have to much oil in the system
Old Jul 2, 2017 | 09:51 PM
steve(ill)'s Avatar
steve(ill)
If there was oil running out, then I assume it had NO R134 left ? At that point they normally FIX the problem, pull a vacuum and add new gas AND OIL.
Old Jul 2, 2017 | 10:16 PM
garyd's Avatar
garyd
They added Freon to get me by and it needs some Freon again. Do I need to add the Freon with oil in it to get by till I can afford to get fixed
Old Jul 3, 2017 | 10:01 AM
alloro's Avatar
alloro
Yes you can. The oil does not convert to a gas like the refrigerant will. So since it cannot covert to a gas it cannot be compressed. Too much oil reduces the cooling ability and way too much oil can lock the compressor.
Old Jul 3, 2017 | 10:02 AM
alloro's Avatar
alloro
No, just use straight R134a.
Old Jul 3, 2017 | 05:57 PM
1999-F150's Avatar
1999-F150
Be careful adding oil. It's almost better to run a little less than too much.
velcro7279
Jul 21, 2016 06:56 PM
Gold Stripe
17
Apr 18, 2012 08:48 PM
F-250 WARHORSE
Jul 8, 2011 08:42 AM
jrs_big_ford_f150
Jul 9, 2003 04:35 PM
levilevi2
Aug 12, 2002 09:58 PM
