Do I need to add oil to my A/C system?
I have a 1994 F 350 that the A/C isn't cooling as well as it should. I know this is r134. I have a manifold set for the A/C that I have used before on other vehicles, so I know how to add the refrigerant. I need to know if I need oil for it before I hook up the gauges to add refrigerant. I saw a TSB about insufficient oil in these systems. That is why I am asking about this.
Any idea how much I should add? I have seen where these can take 9 oz if they are empty, but not sure what to add at this point.
You should be ok adding one of the pressurized cans available at the auto shops. It only holds 2 oz of oil. Make sure to add the correct type of oil. PAG used in almost all of the r-134a systems is very finicky about mixing with other types( POE maybe, but definitely not mineral). PAG comes in different viscosities. PAG100 and PAG46 are two that are avaialable. Check your owners manual for correct identification. Use proper care and precaution when adding the oil so as to not add any trapped air in the hoses.
Gold Stripe
17
04-18-2012 08:48 PM
F-250 WARHORSE
07-08-2011 08:42 AM
GTEK
06-24-2010 10:54 PM
