2004 V-10?????
1. Will it fit?
2. How hard will it be to hook of the electronic ignition?
3. What will the performance be like? (I heard they are good towing motors, which may not give the off the line performance that I would want)?
Any other thoughts?
Thank you
Steve
2. You will need everything off the motorhome. Engine, transmission, PCM, and wiring harness. I'm also assuming this MH is old enough that there is no CAN bus. I don't know when, or even if, that technology started on those chassis but it would complicate the issue tremendously. If you have the wiring harness, it is a matter of connecting everything up and blending power connections into your '60. Virtually nothing on your '60 will "blend" so you will have to wire that part up yourself.
3. Performance: off the line, my 8,000 lb. Excursion at 239,000 miles will still spin both rear tires through the Limited Slip Differential. It should be more than enough for your 3,500 lb. truck. The torque curve is virtually flat from 2200-4500 RPM then the horsepower takes over for the last 500. It's done around 5000. It's not a high performance engine but it has torque unlike any gasoline engine I've ever driven. I own 2 of them: the aforementioned Excursion and an E-450 motorhome.
I researched this swap for my own truck (58 F-100) but never found a parts vehicle, never got started, and decided to go in a different direction.
Lou Manglass
