Adding a front camera to the Sync 3
Old Jul 1, 2017 | 08:20 PM
barnettbill's Avatar
barnettbill
I just got a 2017 F-250 Lariat but it did not have the front camera. Is there a way to add it? The dealer said there was not but I find it difficult to believe that Ford would not make it relatively easy to add one.
Old Jul 1, 2017 | 08:27 PM
Sleepyguy's Avatar
Sleepyguy
Have you tried searching?
Old Jul 1, 2017 | 08:42 PM
barnettbill
Yes, but there seems to be very little info on adding a camera to the existing setup.
Old Jul 1, 2017 | 09:49 PM
Torvvald's Avatar
Torvvald
Good luck! I know there are things that, for sure, can't be added after delivery as they can only be installed at the factory. Most of these have wiring harnesses that would be impracticable to add after the fact...
Old Jul 3, 2017 | 02:44 PM
Stroking2017's Avatar
Stroking2017
Yes you can add one that looks almost OEM. Google camera source. You can even add 360º cameras if you like. I added this camera from camera source: SKU: CS-FHDF. You will also need this camea interface to be able to use your Sync 3 Factory screen. Google Brandmotion Ford MyTouch 8" Dual Camera Interface for Factory Display Radios 9002-2781
I had a local stereo shop install mine and it works great! To activate it all you do is hold the ok button on the steering wheel for 3 seconds and it will automatically come on the screen while in drive or Park. It will automatically go off over 7 miles per hour.
This is where I mounted mine
Old Jul 3, 2017 | 03:15 PM
barnettbill
That looks pretty cool. If you don't mind, how much did you pay total?
Old Jul 3, 2017 | 05:49 PM
klassic's Avatar
klassic
Hi Stroking... what comes with that front camera, cable wise?
Does the cable end in a RCA connector and a 12v input +/-?
I already have an interface for my Sync screen, has another composite input I want to use for a front camera. You've seemed to have found the camera I've been looking for.
Old Jul 3, 2017 | 06:33 PM
Stroking2017
Here is what it looks like on screen. I chose to leave the grid lines on you can disable that if you want though .
Old Jul 3, 2017 | 06:36 PM
Stroking2017
Yes the camera terminates with RCA connections. You can call the camera Source directly they are very helpful. I chose this camera because it looked most Factory. It comes completely loomed. The camera has a 2 pin disconnect under the hood in case you ever have to remove your grill. Plus the camera comes with a 3-year warranty I guess you can't beat that. I did find a similar camera for only $49 with the one-year warranty but I chose to go with this one instead.
Old Jul 3, 2017 | 06:41 PM
klassic's Avatar
klassic
Tell me where to view the $49 camera. I would like to compare that.
I like the looks of the the cam you bought, but $170 US converted to Canadian plus the shipping makes it a little pricey.
Old Jul 3, 2017 | 07:00 PM
Stroking2017
This is the $49 camera. It doesn't come loomed like the camera Source camera. The only difference is the resolution and warranty. I put them side-by-side and they were identical. I kept this one around as a spare just in case but ended up going with the camera Source camera instead.
Old Oct 26, 2019 | 09:58 PM
cgm73's Avatar
cgm73
Could you please send me work order so I can give ma canid to do my 2019 like yours. Thanks
Old Dec 14, 2019 | 11:13 AM
cgm73's Avatar
cgm73
Camara source list this camera as only 2016 compatible, just want to make sure you have 2017 are newer f250, I already see it works. Thanks
Super-Truck
Mar 30, 2017 02:46 PM
lindenj
Oct 29, 2016 02:11 PM
jamhh
Aug 20, 2016 08:33 AM
Matt1966
16
Oct 18, 2015 04:25 PM
dbc001
Nov 13, 2010 11:29 AM
