NP208 Rebuild Question
Old Jul 1, 2017 | 05:04 PM
Resto's Avatar
Resto
I've fully rebuilt my New Process 208 which was pretty straight forward. My concern is that my replacement good used planetary is super tight in the new annulus gear bushing. The old worn out pair would rotate with no effort. I buttoned up the case with all new bearings, chain, seals and new yoke nuts torqued to 120 foot pounds. The yokes rotate not by hand but with a wrench only. Question: Is this radical tightness normal due to the new annulus gear bushing? Has anyone experienced this?
Old Jul 2, 2017 | 12:49 PM
Resto's Avatar
Resto
Anyone have experience here
Old Jul 2, 2017 | 08:02 PM
Gary Lewis's Avatar
Gary Lewis
Nope. Sorry.
Old Jul 2, 2017 | 09:04 PM
82_F100_300Six's Avatar
82_F100_300Six
I rebuilt mine about five years ago. Previous owner had the linkage tied up underneath with a coat hangar to keep it in two high... classic sign of plastic wore out so shift fork won't stay put. Sorry I don't know the names of the parts but I upgraded from the part that had a plastic groove (obsolete) to the one with a metal groove and the plastic sleeves on the shift fork.
To answer your question no that does not sound good. Have you shifted it through each range...4H, 2H, N, 4L....and tried it? Sucks to have to pull it apart if you already sealed the halves with black rtv.
Old Jul 3, 2017 | 10:24 AM
kr98664's Avatar
kr98664
No experience rebuilding an NP208, but I've worked on some other similar models. The binding you've described doesn't sound right. I remember easily turning my rebuilds by hand.
Old Jul 3, 2017 | 12:52 PM
Resto's Avatar
Resto
I agree with you guys and will be splitting the case again. To remedy this I sourced a good used annulus gear and planetary assembly to swap from a correct NP208F. Since there's so many variants between Ford, Dodge, Chevy and Jeep versions not to mention synchronized and non I bet I found combinations of what's not compatible from my pile of NP208 replacement parts. I'll let you know how it works out. Have a safe 4th!
Old Jul 3, 2017 | 01:01 PM
Gary Lewis's Avatar
Gary Lewis
Good luck!
Old Jul 3, 2017 | 04:42 PM
82_F100_300Six
While it's still out on the bench I would shift it through the ranges and see if you can get it to free up. I had an output shaft from a C6 to slide in and turn it.
Old Jul 14, 2017 | 04:50 PM
Resto's Avatar
Resto
The bushing on the annulus gear was causing the binding...not sure why as it was new and installed without problem Ended up swapping a used annulus gear with a decent bushing. All spins well now. Shifted through the ranges and it works. Biggest pain was removing the RTV from the case halfs again.
Old Jul 14, 2017 | 04:58 PM
Gary Lewis's Avatar
Gary Lewis
Glad you caught it before installing it.
9d4
Apr 12, 2013 02:26 PM
jmmartin
22
Mar 21, 2009 11:09 AM
jorgy16
Feb 22, 2006 10:57 AM
