Distributor & Carb, Help
Old Nov 9, 2017 | 09:37 AM
  #46
Tedster9's Avatar
Tedster9
How has it been determined where the timing advances "under load"?
Old Nov 9, 2017 | 10:20 AM
  #47
Boostingaz's Avatar
Boostingaz
Maybe "under load" was a bad choice of words. I have a timing light with an advance dial so I check the timing conditions under idle as well as (in neutral) at approx half throttle.
Old Nov 9, 2017 | 10:53 AM
  #48
Tedster9's Avatar
Tedster9
That's what I figured. If you can get the wife in the engine bay with a timing light cruising down the highway, that'll work though
Old Nov 9, 2017 | 07:53 PM
  #49
Boostingaz's Avatar
Boostingaz
Haha. If she wasn't 8 weeks away from our second daughter the request might go over a little better...or since she is pregnant, if I tell her ice cream is at the end of the tunnel she might just anyways 👍
Old Nov 15, 2017 | 11:52 AM
  #50
Rasputin53's Avatar
Rasputin53
I was looking up using the later (up to 1980) electronic distributor. Rockauto has them for cheap. Look up under Fairmont. Seems pretty straight forward. The later distributor eliminates the points and works with an electronic ignition module.
df85732
Jun 2, 2017 10:23 AM
martymagoo
19
May 16, 2013 07:53 AM
rashanny
Aug 14, 2011 09:44 AM
koolwav36
Oct 2, 2010 05:02 PM
Unimog005
General Automotive Discussion
Feb 25, 2005 11:23 AM
