Different SIZE Spare
Old Jun 29, 2017 | 01:38 PM
bushpilot's Avatar
bushpilot
IS ANYONE ELSE SEEING THIS??
our Platinum 350 (SRW) long bed crew cab has a different size SPARE TIRE...
the 4 Michelins are 275/65 R20's and the spare is a 275/70R18
the spare is a Goodyear Wrangler (which doesnt matter to me) but the 18 vs 20 does bother me...
Old Jun 29, 2017 | 01:46 PM
CRSFX4's Avatar
CRSFX4
Not much different from the old temp spares that were never same size as original equipment.....only meant to tide you over until you get regular tire fixed.
Old Jun 29, 2017 | 01:50 PM
bushpilot's Avatar
bushpilot
my 2004 didn't have a temp spare and this one doesnt either.
at best this means you can NOT rotate the spare as you rotate your tires (its a steel wheel anyway).
Old Jun 29, 2017 | 01:53 PM
manowell's Avatar
manowell
It matches the standard 18" wheel and tires for the 4x2 trucks. The revs per mile aren't much off, and it's meant to be temporary. Doesn't have a TMPS sensor, either. They don't intend you to rotate the spare anymore, it seems. :-)
Old Jun 29, 2017 | 01:59 PM
CRSFX4's Avatar
CRSFX4
I bought a Toyota Sequoia in '05 (still have it, great truck) and the first time the TPMS light came on I checked all the tires and they were within 2 PSI of normal. I called the dealership and the guy said "have you checked your spare?"....had no clue they monitored the spare. They could have pinched me for a new sensor and I would have never known....glad the guy was honest.
Old Jun 29, 2017 | 02:02 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Almost an inch shorter. Not the best idea with a limited slip rear...but with the E-lockers you can get by with it...almost like an open rear end except for the traction control you should be OK if turned off.
Old Jun 29, 2017 | 02:04 PM
nascarjimmy's Avatar
nascarjimmy
they put the 18 as a spare because a 20 will not fit under there!
Old Jun 29, 2017 | 02:07 PM
Paw's 150 Lariat
Unless you want a 35" spare on the 18" wheel!!
Old Jun 29, 2017 | 02:50 PM
AK_SuperDuty's Avatar
AK_SuperDuty
Yeah I think if a person blows a front tire, they're better off moving a rear tire to the front and putting the spare on the rear in the event they need to use 4x4.
Old Jun 29, 2017 | 03:02 PM
kylant's Avatar
kylant
100% incorrect
Old Jun 29, 2017 | 03:12 PM
bushpilot's Avatar
bushpilot
I'm glad Mopar is smarter than that....from the factory my Jeep Wrangler has a matching aluminum wheel/spare AND TPMS emitter in it...and yes it gets rotated.
Old Jun 29, 2017 | 03:17 PM
wfedwar's Avatar
wfedwar
Yep, it will wear out the LS pretty quickly. But as I understand, the DRW are the only ones with LS rear diffs, so this is not that much of an issue.
Old Jun 29, 2017 | 03:22 PM
bushpilot's Avatar
bushpilot
what wheel options are available on DRW's?
do DRW's get 18's (only)??
could be disastrous to run a smaller tire/wheel on a DRW.
Old Jun 29, 2017 | 03:28 PM
natpark's Avatar
natpark
Just FYI, the location under the truck has plenty of room for a 275/65/20 tire, I got a 20" Ford King Ranch rim off ebay and mounted up a 275/65/20 for a full size matching spare. It also looks like there is room under there to go to a 285/65/20. The 295/65/20 may be pushing it.
Old Jun 29, 2017 | 03:34 PM
System's Avatar
System
Prolocutor
It's been this way for the last 3 generations of SD's. Nothing new here. Just Ford saving a few bucks. Back two generations ago when you could have LS instead of the elocker on an SRW with 20's, the owners manual used to tell you that if you got a flat in the rear, to put the spare on the front and put the good 20" from the front onto the rear.
