Bad Injector
Old Jun 26, 2017 | 03:36 PM
Nixoninc's Avatar
Nixoninc
Bad Injector
The truck in my signature has a bad injector in cylinder #8. The injectors have approximately 50,000 mile on them. Would it be a bad thing if I replace only the bad one? Thank you for your help.
Old Jun 26, 2017 | 03:49 PM
xcrsp440's Avatar
xcrsp440
I have replaced one at a time. But when another failed on the same side 6 months later, I did the rest.
Get them from autonation. Around $200.
Old Jun 26, 2017 | 05:09 PM
bismic's Avatar
bismic
Where did you get the injectors from?
Old Jun 26, 2017 | 06:42 PM
Nixoninc's Avatar
Nixoninc
The current injectors were installed by a Ford dealer back when it had 95,000 miles on it while it was still under warranty. It now has 145,000 miles.
Not sure if this makes any difference, but I'm the second owner. I bought it with 105,000 miles on it. The original owner was a fire department. I've been vary **** about maintaining it like how it has been suggested on this forum. Oil changes every 5,000 miles, new fuel filters every other oil change. HFCM get drained every oil change. Only OEM filters. I'm a bit perplexed why an injector would go bad after only 50k miles. Shouldn't they last longer?
Old Jun 26, 2017 | 06:51 PM
bismic's Avatar
bismic
Yes they should. Not unheard of to occasionally get one bad apple though.
Old Jun 26, 2017 | 11:39 PM
clarkmetalservice's Avatar
clarkmetalservice
low fuel pressure
Old Jun 27, 2017 | 01:03 AM
Nixoninc's Avatar
Nixoninc
Originally Posted by clarkmetalservice
low fuel pressure
I'll check that. I did the Blue Spring upgrade right after I bought it.
Old Jun 27, 2017 | 01:07 AM
Nixoninc's Avatar
Nixoninc
Do I need to buy anything else besides the injector? Copper washer?
Old Jun 27, 2017 | 11:12 AM
FiznUKa's Avatar
FiznUKa
If you get a ford reman they are ready to install out of the box. The orings and copper washer are installed already just need to oil up the orings and slide it home. Also oil the top of the injectors with oil before installing the oil rail as not to cut the orings ontop of the injector.
Rogue427
Dec 11, 2018 02:14 PM
RenoHuskerDu
33
Oct 25, 2017 08:31 PM
mark r / 019
Mar 11, 2014 10:20 PM
LSAtexan4x4
Mar 8, 2013 02:18 PM
PhilnMarilyn
Aug 18, 2010 07:14 PM
