Over heating while ac is on?
Old Sep 13, 2017 | 12:22 AM
  #31
gr93's Avatar
gr93
Check front cab mounts
Had similar problem a while back.
Have 2nd mech temp gauge installed. Lifesaver.
Front rubber cab mounts were shot;
The brackets on the rad support were rusted totally out.
Lower frame brackets were ok, except holes were larger (rust?).
Common problem confirmed in salvage yards.
Front of cab dropped low enough to cause the fan to rub on the shroud.
Correct solution is new rad support. Big job.
R.I.M. (repaired it myself)
Measured drop, using bumper and even gap fan clearance in shroud as guides.
Bought new hd galv brackets, thick galv metal backing plates.
Used (gulp) large GM Suburban rubber, new bolts, washers.
Problem solved.
James128
Jul 3, 2018 06:25 AM
89ford73
37
Jan 7, 2013 10:01 AM
CrewCabLongbox
Jul 18, 2012 10:29 AM
texas F 250
Nov 1, 2010 07:38 AM
orangeford
May 27, 2002 09:13 PM
