Fuel line size
Old Jun 25, 2017 | 10:28 AM
bulldogcountry1's Avatar
bulldogcountry1
Fuel line size
I have a '78 F250 2wd LB with dual tanks. I just relined the inside of my rear tank, and I did the side tank about a year ago. I just bypassed the rear tank and ran a rubber line to the mech fuel pump in the meantime.
I'm now ready to reinstall the rear tank, a new selector valve, and an electric fuel pump. I plan to keep the existing steel lines. Unless I am mistaken, all the stock components were 5/16", right?
The new steel, pre-bent lines I see are 3/8". My question is what is the point of increasing the line diameter unless everything in the system is 3/8"? The sending unit lines are going to 5/16", and the selector valve is 5/16". Is it wise to have inconsistent sizing in the lines?
Old Jun 25, 2017 | 10:41 AM
KULTULZ's Avatar
KULTULZ
Post
3/8" is normally for HI-PO or high demand engines. Intermingling is a waste of money (IMO) and will be harder to service in the future.
https://www.inlinetube.com/brake--fuel-lines
Old Jun 25, 2017 | 11:35 AM
PapaBearYuma's Avatar
PapaBearYuma
On my trucks, in stock form, everything behind the fuel pump was 3/8 and everything in front was 5/16. Don't know why.
Only reason I can think of is that it increases the flow speed and/or pressure to prevent vapor lock.
Old Jun 25, 2017 | 01:13 PM
bulldogcountry1
Hmm... I know the line from pump to carb is 5/16. Maybe I am mistaken on the hard line from pump to valve. I'll check this afternoon.
Old Jun 25, 2017 | 02:54 PM
KULTULZ's Avatar
KULTULZ
Post
Sounds like I am mistaken also...
Old Jun 25, 2017 | 03:15 PM
Blue and White's Avatar
Blue and White
My truck (F250/400) is 3/8" behind the pump and 5/16" from pump to carb. I understand some trucks were built with 5/16" behind the pump.
After the fuel is pressurized by the pump, line size, restriction and tendency to vapor lock is not much issue. 5/16" is plenty.
Before the pump, different story. The pump is sucking the fuel and pressure is low. Restriction there can eaisly cause vapor lock. A bigger fuel line helps minimize restriction.
One thing to watch out for are re-pop fuel senders. I could not find one for the rear tank that was 3/8" to match my lines. I had to adapt a 5/16" pickup.
Old Jun 25, 2017 | 04:12 PM
bulldogcountry1
So it seems that my hard lines from tanks to pump is 3/8" after all. My original pickup tubes were 3/8", but the new ones are 5/16". My new valve selector is somewhere in between.
Based on some old threads here, I planned on mounting the electric pump near the selector valve. Now, I have to do something where the mech pump was.
1. Bridge the gap from the 3/8 line to the 5/16 pump to carb line with hose.
2. Replace the 5/16 line with 3/8 hose
3. Replace the 5/16 line with a new 3/8 line and bridge the gap with hose.
Old Jun 25, 2017 | 04:27 PM
PapaBearYuma
Run 3/8" hose from the crossmember to the carb. Easy enough to clamp it down tight on the 5/16 nipple. Or replace the 5/16 nipple with 3/8". I did that on my yellow truck. About $7 on eBay
Old Jun 25, 2017 | 04:52 PM
mikeo0o0o0's Avatar
mikeo0o0o0
From tank to fuel pump is 3/8", from fuel pump to carb is 5/16".
Old Jun 26, 2017 | 12:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assy-Use with factory installed mid-ship & aft axle fuel tanks / Obsolete
1975/79 F100/350.
The fuel tank selector switch located in the heater control panel switches the tanks and the dash fuel gauge from one tank to the other.
Old Jun 26, 2017 | 04:14 AM
KULTULZ's Avatar
KULTULZ
Thumbs up
Talk about common sense...
THANX!
columbia1spring
Sep 4, 2017 11:55 AM
Jonnys.1991
Apr 2, 2015 07:49 AM
Boba Fett
Feb 22, 2015 07:57 AM
Dorsai
May 22, 2012 09:43 AM
Centroplex
Jun 7, 2007 07:41 AM
