2011 Escape Fan Switch Issue
Hi Guy's
does anyone know why the fan selector switch only works on 4?
also why would the radiator fan come on instantly when you start the engine and select defrost.
Thank you
Thank you
The radiator fan behavior you described is completely normal.
Go to your nearest Ford dealer and request for Motorcraft part number YH-1715 for your replacement blower motor resistor and replace it yourself. Here is a pictorial of its location that can be easily accessed by simply opening the glove box.
Originally Posted by 2011 Ford Escape Workshop Manual Section 412-01
412-01 Climate Control
2011 Escape, Mariner, Escape Hybrid, Mariner Hybrid
REMOVAL AND INSTALLATION
Procedure revision date: 07/22/2010
Blower Motor Resistor
Item
Part Number
Description
Blower motor resistor electrical connector (part of 19D887)
W701696
Blower motor resistor screw (2 required)
Removal and Installation
Lower the glove compartment.
Disconnect the blower motor resistor electrical connector.
Remove the 2 blower motor resistor screws.
To install, tighten to 3 Nm (27 lb-in).
Remove the blower motor resistor.
To install, reverse the removal procedure.
Item
Part Number
Description
W701696
Milwaukee1979F150
Dec 10, 2011 06:34 AM
TheTowingCowboy
29
Jun 18, 2010 04:13 PM
PaulC
Aug 24, 2004 08:39 PM
