Hub lock assembly
Old Jun 24, 2017 | 11:58 AM
Cyrusjohn's Avatar
Cyrusjohn
Hub lock assembly
On the drivers side hub lock mechanism, there are two circlips that go in the groove (behind the plastic split bushing). It doesn't look normal. The other side only had one.
See two clips, everything laid out starting from the left. I think there should only be one. Two are tight in the groove. The second one may not be completely seated??
Old Jun 24, 2017 | 06:02 PM
Franklin2's Avatar
Franklin2
Here's a diagram.
Old Jun 24, 2017 | 06:45 PM
Cyrusjohn's Avatar
Cyrusjohn
Thanks Dave. Mine does not look like that diagram. I have a 1984 F250 with Dana 44HD front TTB. I think it is all stock. My actuator in the chrome hub on mine is all plastic cups and helix. The part in the photos is the internal locking mechanism. The pictures I took are not the best. I think I am going to take one clip off. I have never seen two snap rings in the same groove.
Old Jun 24, 2017 | 09:50 PM
CharlesStuber85F150's Avatar
CharlesStuber85F150
First of All do you have the factory hubs or aftermarket hubs?
Old Jun 25, 2017 | 05:05 AM
Cyrusjohn's Avatar
Cyrusjohn
I don't know if my hub locks are original or aftermarket. I will post more pictures later.
The dial does not say "FORD" across it.
Old Jun 25, 2017 | 06:06 AM
CountryBumkin's Avatar
CountryBumkin
Here's another parts view of a "Warn" manual locking hub:
Old Jun 25, 2017 | 12:39 PM
Cyrusjohn's Avatar
Cyrusjohn
This second clip is not going back on.
Yes Mike, that is what I have. Thanks for the pics, that doubled up clip is not going back in. Perhaps at the factory two clips were stuck together and they went on as one.
Is there a forum rule about posting too many pictures.
Old Jun 25, 2017 | 02:40 PM
CountryBumkin
There should not be two snap rings (clips) used.
I would disassemble and check the groove where the snap ring seats. Is it wide enough to fit two snap rings?
If it is wide enough to two snap rings then I think it is worn out or damaged. Perhaps (previous owner or repair shop) mucked it up or came up with a fix for worn out groove (using two clips). Maybe the second snap ring was never seated in the groove. IDK.
Old Jun 25, 2017 | 07:36 PM
Cyrusjohn's Avatar
Cyrusjohn
I don't think the snap ring was fully seated in the groove. It came off a lot easier then the next one. I will take it apart again and see if two rings can really go on that little inner gear groove.
Thanks again
Old Jun 27, 2017 | 10:30 PM
CharlesStuber85F150
Here is a new set of Warn Hub Lockouts and the necessary parts for installation
Old Jun 27, 2017 | 10:33 PM
CharlesStuber85F150
here is a NOS set of Ford (Warn) Hubs NOS E1TZ-1K104-B Ford 1/2 Ton Dana 44 Locking Hubs Red Dial 19 Spline Warn 9790 | eBay
Twonky
Nov 14, 2018 05:42 PM
High Intentions
Feb 24, 2015 04:19 PM
dpilot83
Sep 11, 2014 10:06 AM
kraylake
Jan 5, 2012 10:54 AM
79-400-POWER
Offroad & 4x4
Aug 16, 2007 03:25 PM
