Sponsored by: Real Truck
Oil cooler help
Old Jun 24, 2017 | 08:05 AM
dubnasty216's Avatar
dubnasty216
Oil cooler help
I have a 2003 f250 6.0 from what I have read, it is showing signs that the oil cooler may be going bad. I have done EGR delete, head studs & head gaskets. At 65MPH my engine oil temperature is about 10 degrees warmer than my engine cooler temperature. However, unless I am towing my engine oil tempature doesn't get higher than 212 degrees & both cool down relatively quickly at idle. Stop & go traffic makes the tempature difference jump to 14-15 degrees. I am getting ready to move across the country. Do I need to plan on replacing my oil cooler before I move?
Old Jun 24, 2017 | 10:23 AM
jsm180's Avatar
jsm180
Sounds normal to me.
All the info you need is here. https://www.ford-trucks.com/forums/3...ch-folder.html
Old Jun 24, 2017 | 01:45 PM
bobv60's Avatar
bobv60
Sounds like you are ok to me also.
Old Jun 24, 2017 | 03:26 PM
dubnasty216
Also okay that my transmission temp gets up to about 180 in stop and go traffic?
Old Jun 24, 2017 | 04:13 PM
dubnasty216
Ive been driving at 60mph for about 30 minutes now and it's 94 degrees out here in central Florida
Old Jun 24, 2017 | 07:08 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Looks almost exactly like my numbers yesterday, 65 on the highway when it was 95* here. Even EGT matches
Trans at 180* in traffic is fine. As far as it hitting 15* difference, you might still be in the window you can do a half-flush; you drain the engine, pull the EGR outlet cover off the oil cooler base plate, suck the coolant out and put in a cleaning agent. Let it work awhile, then suck it out, button it upm and flush to plain water. A couple of guys have tried and said it made a big difference for them without doing a full chemical flush on a partially plugged cooler. But that's for another day, I wouldn't sweat it before the move.
dubnasty216
Jul 12, 2017 01:43 AM
wisevoss
Jan 29, 2014 04:51 PM
jl4407
Jul 5, 2012 12:23 AM
chromedom
May 19, 2010 12:19 PM
Rockledge
All Things Towing
Jun 12, 2004 11:07 AM
