Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1972 F600 steering
Old Jun 22, 2017 | 08:39 PM
larrybird33647's Avatar
larrybird33647
1972 F600 steering
I have a 1972 f600 with manual steering. Everything I can find on here seems to indicate that 73-79 will interchange. What years will work with a 72? What about power steering from a 77? Thanks for any help.
Old Jun 25, 2017 | 07:22 PM
larrybird33647
anyone?
Old Jun 25, 2017 | 09:58 PM
Notmeofficer's Avatar
Notmeofficer
Larry.. I have both trucks..a 67.. and several 73 thru 79s...
The frames appear the same to me... so it appears everything from a 73-to79 will bolt on over...
To do the conversion you would need everything however
And especially the spacers for the PS box.. to space it away from the frame properly
The PS pump is easy.. because you can adapt just about any pump..I suggest saginaw.. if you are making the conversion
Make sure you get the correct pitman arm...
I may.. repeat may... have a line on everything..Im scheduled to get several f600 parts trucks in the next month or so
If you look under my threads you will find one showing a bare primered frame with manual steering... it might be helpful to look at
https://www.ford-trucks.com/forums/1...an-f600-3.html
post 42 iirc
Old Jun 26, 2017 | 12:28 PM
larrybird33647
Thank you very much, I may go back with manual for now, I have steering column , box , and some different linkages for the clutch from a 77. I only need a pump and some lines
427 fordman
92
Jun 1, 2013 11:35 PM
croc58
Jan 4, 2013 02:52 PM
palehorse13
20
Jun 28, 2012 12:36 PM
abnjumpmaster
Jan 31, 2009 10:04 PM
76fordo
Mar 13, 2008 09:50 PM
