Tips and tricks
Old Jun 22, 2017 | 04:09 PM
SkidsUP's Avatar
SkidsUP
Tips and tricks
Anyone know any tips or tricks about the 2017 SD that we may not be aware of?
I just learned to roll the front windows down with the key fob by pressing unlock and then holding down the unlock button while standing outside of the truck. Sorry if I'm late to the party on this one.
Old Jun 22, 2017 | 06:24 PM
mhoefer's Avatar
mhoefer
yes, you have to have remote settings selected for window opening. Go into the settings tab on the far right, there is a whole bunch o stuff to play with. Auto hi beam, auto easy entry/exit, remote settings for HVAC and heated steering wheel.
To truly find all the gems go through each tab seperatly, customize the far right tab for what you want to see most importantly. easy to tab up and down in it while driving, but have to be in park for some of the things when adjusting settings.
Old Jun 22, 2017 | 07:20 PM
467echo's Avatar
467echo
Trick I learned about the power running boards:
If you put pressure on them when out and door open then you close the door, they will stay out. Helps when you go to wash it!
Old Jun 23, 2017 | 06:01 AM
Xwild's Avatar
Xwild
467echo.. there's also a menu setting for that.. they'll also retract if they try to open and you're standing close. They barely touch you and pull back up.
Old Jun 23, 2017 | 06:45 AM
RugbyRef's Avatar
RugbyRef
THAT is a great tip! Thanks!
TN_Explorer
1997 - 2003 F150
Dec 4, 2021 02:21 PM
cal2050
Sep 29, 2018 04:38 PM
dalej
Jul 29, 2017 07:16 PM
elmerfudd51
Jul 28, 2015 11:36 PM
ecajberry
Jul 3, 2004 11:06 AM
