Sponsored by: Real Truck
Rear Head rest removal ??
Old Jun 21, 2017 | 07:23 PM
Bigmike1461's Avatar
Bigmike1461
I have a 2016 F350 super cab and I can't figure out how to remove the rear head rest. Short of taking out my sawsall and cutting them off. Does anyone know how to get them off... Thanks
Old Jun 21, 2017 | 08:24 PM
Doc Foster's Avatar
Doc Foster
8th Gear
I have a 2016 Superduty Crew cab, and they were a bear to get out. If I remember I had to push the small buttons on the inside of the metal posts simultaneously and pull upward with a lot of force. Don't know if the same as yours.
Old Jun 21, 2017 | 11:39 PM
rspeters's Avatar
rspeters
Yep, push the small buttons on each post at the same time and push up with the side of your hand. Not easy, but not too bad once you get the hang of it.
Old Jun 22, 2017 | 06:37 AM
Chuck's First Ford's Avatar
Chuck's First Ford
that is much easier then doing it on a 2012 Super Cab.
Old Jun 22, 2017 | 08:57 AM
Bigmike1461
There are no little buttons to push...My old F150 had the buttons this doesn't. The headrest have holes in them to see-through . I can't find any buttons
Old Jun 22, 2017 | 10:45 AM
Chuck's First Ford
do a search.. video .. for 2016 XL.or XLT... using a 18 inch screwdriver.. 2 clips way down the rear of bench upper seat. to unlock upper rear seat.
then the head rests are bolted to rear wall..
that is how the 2012 XL is done
you do not state what level of trim package your truck has.
Old Jun 22, 2017 | 11:48 AM
seville009's Avatar
seville009
Similar thread with pictures
https://www.ford-trucks.com/forums/1374967-2015-headrest-removal.html
Old Jun 22, 2017 | 02:47 PM
Bigmike1461
I have a Lariat
Old Jun 22, 2017 | 02:58 PM
Bigmike1461
I have this type headrest.
Old Jun 22, 2017 | 06:47 PM
seville009's Avatar
seville009
In your last picture where you're holding down the cushion, it almost looks like that bracket holding the headrest is bolted to the back of the cab. If so, may have to pull off the back of the seat to get at the bolts.
Old Jun 22, 2017 | 07:31 PM
Bigmike1461
No I can get my finger between the bracket and wall... But I might have to pull out seat back.
Old Jun 22, 2017 | 07:57 PM
I.B. Washincars's Avatar
I.B. Washincars
I can see why you would want to remove them. They look like they would block your view quite a bit, not to mention that they are hideous.
Old Jun 30, 2017 | 11:27 PM
Bigmike1461
Head rest gone
I found a video on you tube and they showed how to remove seat back once seat back was removed just had to unbolt headrest. Much nicer with out them. Don't need them no
one sits back their but the dog.
MBDiagMan
Dec 13, 2015 01:52 AM
the_auto_tech
Oct 16, 2012 09:44 PM
brcman
2009 - 2014 F150
Jun 14, 2011 06:31 PM
6overZilla
Ford vs The Competition
Feb 8, 2006 01:04 PM
coachhomer
Jul 15, 2004 04:47 PM
