Replace factory LSD with Open Diff?
Old Jun 19, 2017 | 01:47 PM
firmwareguy195's Avatar
firmwareguy195
Greetings:
Anybody know whether any of the aftermarket open carriers will fit in an 8.8 housing that originally came with a LSD, and use the existing ring gear? The LSD that came from the factory needs an overhaul. Seems like a good opportunity to install a lunchbox locker, which of course doesn't fit in the LSD carrier.
My main questions is whether the width of the open carrier is close enough to the LSD width to be shimable?
Thanks
Old Jun 19, 2017 | 07:07 PM
steve(ill)'s Avatar
steve(ill)
I would think the company that MADE the locker would be the best bet for telling you which housing it will fit into.
Old Jun 19, 2017 | 07:14 PM
firmwareguy195
Hi Steve. My question is not whether the locker will fit in the carrier. It is whether the open carrier will fit in the LSD pumpkin.
Thanks
Old Jun 19, 2017 | 07:21 PM
Conanski's Avatar
Conanski
Originally Posted by firmwareguy195
Greetings:
Any 8.8 carrier will fit this axle and use the existing gears, and yes the new diff may require a different shim combo for proper setup but if you're going through all that trouble why not just install a complete aftermarket diff like the Detroit truetrac or locker?
Old Jun 19, 2017 | 08:46 PM
firmwareguy195
Paul:
Thanks for your reply. It seems reasonable to me that the axle would fit any 8.8 carrier, but it's worth clarifying before I buy something that doesn't fit.
I hadn't really looked at the Detroit Locker option. I guess that would replace the carrier entirely. Cost wise, it's probably a wash, and the result would probably be more stout than the open diff/droppin locker. Definitely worth checking out.
brassplyer
Dec 21, 2018 08:12 AM
Chris Braun
Mar 17, 2013 12:28 PM
FireBlue
25
Jun 29, 2010 10:18 PM
Ford_Six
Jan 21, 2009 12:49 AM
spixican07
1978 - 1996 Big Bronco
Nov 4, 2002 05:44 PM
