Differential guide
Old Jan 15, 2009 | 09:14 PM
Ford_Six's Avatar
Ford_Six
Differential guide
Is there any guide to differential carriers, or a site with dimensions? I'm trying to find a locker I can modify to fit a vehicle that doesn't have one available.
Old Jan 15, 2009 | 10:37 PM
85e150's Avatar
85e150
WHAT would not have a locker available? Seems like you can find ls or lockers for anything.
Old Jan 16, 2009 | 08:28 PM
Ford_Six's Avatar
Ford_Six
A Ford Courier. Not even a limited slip factory option.
Old Jan 16, 2009 | 10:45 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Think a Mustang 8.8 would fit under there? Can't beat the parts availability for that diff!
Old Jan 16, 2009 | 11:03 PM
Ford_Six's Avatar
Ford_Six
It's a dropout carrier, 8" ring gear, and looks very similar to a Toyota 4cyl carrier except for the carrier bearings. This one uses 40mm ID bearings, while the Toyota one uses 45mm or 50mm ID bearings.
I sent an e-mail off to Eaton asking if they had any sort of info they could part with, but haven't gotten anything.
The truck is six lug, I'd like to keep it that way, as would most owners. I also like the center drop out design, and wouldn't swap this thing out for an 8.8.
Old Jan 21, 2009 | 12:49 AM
85e150's Avatar
85e150
Aren't there Toyota 6 lug axles? They use that axle in lots of stuff IIRC.
DrDecay
Apr 4, 2014 10:08 AM
hop
Dec 14, 2008 05:54 PM
kermmydog
1947 and Older Ford Trucks
Aug 21, 2004 01:01 PM
paulbp
1978 - 1996 Big Bronco
Oct 25, 2001 03:34 PM
