After reading some posts I'm even more confused. My Door Payload sticker say 1500lbs (for people & Cargo) on my 2017 F250 6.7 short bed. The question I have is when towing a trailer does the bumper hitch or 5th wheel weight of 1000LBS get subtracted from what the Door Payload sticker says? if so that leaves only 500 pounds, so I am 235 wife 150= 385 not much left. Doesn't seem right.
[QUOTE=SkidsUP;17269111]After reading some posts I'm even more confused. My Door Payload sticker say 1500lbs (for people & Cargo) on my 2017 F250 6.7 short bed. The question I have is when towing a trailer does the bumper hitch or 5th wheel weight of 1000LBS get subtracted from what the Door Payload sticker says? if so that leaves only 500 pounds, so I am 235 wife 150= 385 not much left. Doesn't seem right.[/QUOTE
First of all, the door sticker is correct. You only have as much as it says for hitch weight or pin weight plus passengers and gear.
Unfortunately you have discovered that the true limiting factor for towing is the payload rating, and not the max towed weight. This is a common issue with a f250 with the diesel engine combined with a high option level. The 6.7l alone lowers payload by about 700 lbs, and all those options take care of the rest.
This is the reason I went from a F-150 to a F-350.
The F-150 only had a 1500 lb payload, and my travel trailer hitch weight, passengers, and gear exceeded that by a fair margin. That truck was not a stable towing platform with those conditions.
There some on these forums that argue you should ignore that sticker, and tow whatever you want, however I do not subscribe to that theory. I personally will not intentionally load beyond the ratings. Doing that got me into trouble with my previous truck.
My current F-150 has payload of#1607lbs and I was at the limits with my 5er lite so I started on the trail of buying a SD. Knowing the situation of my friend WRT payload and F-250 diesels I considered the 6.2 gas. However, seeing how we’re doing several major trips over mountain passes and the like I settled on a F-350. I figured that I’d keep the base GVWR as in my province the DOT (bumblebee police; found out their called that because of the paint scheme of the vehicles) do go by GVWR, payload, GAWR, and tire load rating when the do their spot checks. (Based on what I’ve read). So although I’ll have to pay higher registration, insurance and the like. I know that I’m 100% complient and safe (most importantly).
Yes. You're absolutely correct.
F-250's aren't great for towing 5th wheels for this very issue. I originally wanted a 250, but when I did the research, we went with a 350.
I'm lost on the varying Door Pay Load sticker differences.
2017 F250 6.7 short bed has 2086# Platinum with 20" wheels.
I can see a few hundred pounds but 1000???
