Vacuum suction spec?
Old Jun 18, 2017 | 09:30 AM
Boondockdad's Avatar
Boondockdad
Anybody know what it should be making inHg?
Having power brake issues. Replaced the pump once already, and one year later it's starting again. Basically, pedal hardens up and dash 'brake' light come on at idle/low speed.
Thanks
Old Jun 18, 2017 | 09:43 AM
Walleye Hunter's Avatar
Walleye Hunter
Thanks
F models don't have vacuum brakes, ours are hydro boost hydraulic assist. Someone here might know but you should also try in the E model section.
Old Jun 18, 2017 | 10:35 AM
Boondockdad
OK.
In inHg:
Vacuum on hose out of pump is 5 idle, 15 at 2100 rpm.
Vacuum on the distribution manifold is 2.5 idle, 11.5 at 2100 rpm.
And it's a gradual drop back, about 3 sec, to idle vacuum when I take foot of accelerator.
Old Jun 19, 2017 | 05:05 PM
Boondockdad
Never did find specs for mechanical vacuum pump, but based on generic numbers my pump was way low.
Changed it out, along with power booster check valve.
New pump running 25 inHG at idle. Brakes all good.
Old Jun 22, 2017 | 12:14 PM
retiredsparky's Avatar
retiredsparky
Another way to approximate what the vacuum should be is that a gas engine max vacuum is in the low 20 inches, so those vacuum systems are designed for use on gas engines. The pumps are just imitating to make the same equipment like hvac controls and brakes operate the same way. For motor homes with vacuum systems, they just use more vacuum diaphragms for the rear brakes.
danlee
Mar 21, 2017 08:25 PM
fordtrucksforever
Jan 8, 2016 01:57 PM
tiopet
Aug 25, 2012 04:16 AM
Paul J.
General Diesel Discussion
Mar 5, 2011 05:38 PM
bricklayer
Mar 10, 2007 06:35 AM
