vacuum pump
Old Mar 9, 2007 | 05:08 PM
bricklayer's Avatar
bricklayer
vacuum pump
Hay- how many inches of vacuum should I have at the pump? I am looking at about 25.I have had a problem with my brakes and am woundering if 25 inches is enough.Thanks
Old Mar 9, 2007 | 05:34 PM
brownieboy525's Avatar
brownieboy525
you should have at least 18in of vacum
Old Mar 9, 2007 | 07:48 PM
PLC7.3's Avatar
PLC7.3
At curb idle (650rpm) there should be 21 inches.........within 30 seconds.
Old Mar 9, 2007 | 07:49 PM
PLC7.3's Avatar
PLC7.3
At sea level and at curb idle (650rpm) there should be 21 inches.........within 30 seconds. Higher altitudes make a difference.
You mentioned 25 at the pump......... it should be taken either at the vacuum manifold or at the booster.
Old Mar 10, 2007 | 06:35 AM
bricklayer's Avatar
bricklayer
I am having a problem with the brake pedal drop after the truck is started.I checked vacuum at pump,manifold,and booster all showing 25in. If I run a hose from the pump to the booster the pedal stays up.This makes no sence,when I have 25in at all locations.
tjc transport
19
Jun 16, 2025 06:23 AM
mark vanford
Oct 14, 2024 12:31 AM
wildstang
Sep 10, 2010 12:00 PM
smuzz
Nov 16, 2005 06:37 PM
portlandtn
Jun 26, 2005 11:46 AM
