Wiring issue???
Old Jun 23, 2017 | 10:02 AM
  #46
Kevsf150's Avatar
Kevsf150
Originally Posted by Gary Lewis
Kev - You said that Accessory doesn't do anything. But then you say the radio, heater, etc all work fine - but you didn't saywhether that is with the key in On or in Accessory. So, can you see why I'm confused?
But your procedure on the ignition switch looks good - if you got the right hole to put the drill bit in. There are several holes, and the one you want is not easy to see. But with the bit in there it locks the switch in the Off position - although the bit is small enough that it would be easy to break it if you forced the key.
So, are you sure you did the ignition switch alignment correctly. I ask because it really seems like the switch is the problem. And NotEnoughTrucks is right - the tilt wheel columns are notorious for breaking internally, and that may be part of the problem. So, is your column a tilt unit?
Also, did you bring any components over from the 86 besides the frame. NotEnough is right that the early 81 trucks had some wiring differences, so any part from a later truck is suspect.
-the radio and heater work in the run position nothing works in the accessory position
-yes, I'm sure I installed the switch right.
--no, i bought the truck like this. The previous owner built this truck and he parked this truck because it had a "wiring issue". I didn'think it would of been this bad
Old Jun 23, 2017 | 10:06 AM
  #47
Kevsf150's Avatar
Kevsf150
While I agree that this isn't the typical failure mode for the "famous piece", who knows what all it can do? But we are thinking alike - there's something amiss in the column, either mechanically or electrically.
whats the "famous piece" and how do you check it see if the steering is the problem?
Old Jun 23, 2017 | 11:20 AM
  #48
Franklin2's Avatar
Franklin2
Here's a link about the piece in the column. By the way, the local parts stores carry this piece now, that's how common it is for it to break.
https://www.ford-trucks.com/forums/8...k-in-park.html
You have to pull the steering wheel, the turnsignal switch, and get down in there to get to it. You probably should be in there anyway though to check for other problems also.
Old Jun 23, 2017 | 11:47 AM
  #49
WhatsAChevy?'s Avatar
WhatsAChevy?
Might be a good idea to replace the headlamp dimmer switch also while your visiting this "ghost in the machine" issue. They are inexpensive enough.
Old Jun 23, 2017 | 05:34 PM
  #50
kr98664's Avatar
kr98664
Not sure where better to ask, but the thread referenced above is 8 years old. Is this infamous piece found on all tilt columns, both auto and manual? Or is it only on auto trucks?
My truck has a 4-speed, so am wondering if my truck even has this piece and if I should consider a precautionary replacement. If it matters, I keep my tilt locked in one position, and never change it.
Old Jun 23, 2017 | 05:51 PM
  #51
Gary Lewis's Avatar
Gary Lewis
It is covered here: Steering Columns - ???Gary's Garagemahal. But the answer is that the part in question was used on all 1980 - 1989 E, F, and U 100's through 350's that had tilt wheels. But, in Dec of 1988 Ford replaced that part with another one. Hopefully it fixes the problem.
Old Jun 23, 2017 | 07:42 PM
  #52
Franklin2's Avatar
Franklin2
My 89 had that part and it was broken when I bought it. First one I did.
Old Jun 23, 2017 | 09:07 PM
  #53
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Yup. All tilt columns up to and including 91 used this piece. Does not matter auto or manual. The breakage is a function of the stress and leverage placed on the actuator, not by operation of the tilt. Precautionary replacement is not necessary. It is a PITA to change. I have had them last for years and I have had a new one break in a matter of weeks.
The symptoms of a broken actuator can make the link between the actuator rod and the key cylinder very sloppy, which often makes it difficult to turn the key to the start position. It also could cause a problem with locating the "off" position when adjusting the switch contacts. I am wondering if this might be the case and the inaccurate adjustment shows up as the inability to turn the switch to the accessory position?
Old Jun 23, 2017 | 09:21 PM
  #54
kr98664's Avatar
kr98664
Thanks, yes, that was very helpful. Here's a link you referenced on your website, showing the complete replacement process:
Ignition Actuator Replacement on an '85 w/tilt - Ford Bronco Forum
Hope I'm not hijacking the thread. Should we move this to a new one? You see, I have a couple more questions:
1) If this piece breaks on me at some remote location, is there a reasonable workaround to get the truck started and limp home? I carry enough tools to do some basic work. For example, I'm wondering if I could drop the steering column and then grab the rod with a pair of pliers to actuate the ignition switch.
2) Does anybody make an upgraded (read: stronger) version of this fragile part?
Old Jun 23, 2017 | 10:22 PM
  #55
Gary Lewis's Avatar
Gary Lewis
Dunno about another thread, but there's a good possibility that the OP's part is broken.
Anyway, grab the link with a pair of pliers or vice grips and pull up to start.
Old Jun 24, 2017 | 12:56 AM
  #56
Franklin2's Avatar
Franklin2
If it ever happens on the road, all you need to do is take the short little cover off that goes around the column near the cluster. You will need see a metal rod on top of the column and it will move when you turn the keyswitch. Take the keyswitch and turn it as far as you can like you are trying to start the truck, and then take some pliers and grab the rod on top of the column and shove it downward toward the cluster. It should start.
Then if you have a automatic, it probably won't move out of park. To get it to move out of park take a small screwdriver and in the same metal rod area poke backward up the column toward the steering wheel to align the broken piece so the lever will move. That is what the notch is for in the lower portion, to keep the tranny lever from moving in the off position.
This link supposedly has a easier way to install this piece.
https://www.ford-trucks.com/forums/1...-easy-way.html
Old Jun 24, 2017 | 04:52 AM
  #57
Kevsf150's Avatar
Kevsf150
ok Ill try it, but I'm going to be away for a week or two so I'll let you know how I make out when I get back, thank you
Old Jun 24, 2017 | 07:26 AM
  #58
kr98664's Avatar
kr98664
Groovy! Thanks for the info, including the links. That has put my mind at ease about getting home if this part fails.
[/hijack mode off]
Old Jun 24, 2017 | 09:00 AM
  #59
NotEnoughTrucks2014
The illustration in Franklin's post (#56), shows why and where the actuator breaks. The shortened replacement procedure referred to is kind of controversial and it is worth reading the link to find out why.
I would not cut the actuator as described. That extension serves the function of a guide and it slides in a close tolerance channel. Cutting off that last 1\4 inch dramatically shortens the effective length of the guide and greatly increases the chance of binding which will result in yet another broken actuator. That said, the shortcut does work, but you take your chances. The main reason for considering this is the tilt spring which must be compressed during assembly. It actually is not difficult when you try it, but it is somewhat unsettling when everything springs apart on disassembly. Take your time and work logically. It takes me about an hour to do, but I have done it several times.
Old Jun 24, 2017 | 09:08 AM
  #60
Gary Lewis's Avatar
Gary Lewis
So, you haven't learned to quit pulling yourself in with the steering wheel?
