Sponsored by: Real Truck
Belt replacement; when ?
Old Jun 16, 2017 | 10:50 PM
Greynomad's Avatar
Greynomad
The 2013 250 DSL is coming up on 95 thousand miles. What is the recommended
mileage to change out the belt? I pull a 15 thousand pound 5th wheel and spend a good part of my time running around the outback in some of the nastiest real estate possible.
Old Jun 17, 2017 | 03:33 AM
seville009's Avatar
seville009
If you're thinking about it, just do it. They're not expensive, but if it does break, you're dead in the water. Kind of like a battery - for what it does, I stick a new one in every three years.
Old Jun 17, 2017 | 04:30 AM
Just Strokin's Avatar
Just Strokin
Replace it and then carry your old belt as a spare. You will breath easier and worry less.
Old Jun 17, 2017 | 06:12 AM
Chuck's First Ford's Avatar
Chuck's First Ford
as above.
and replace all Idlers pulley's... keep old ones just in case..
I changed mine last Fall.. all Motorcraft parts. Rockauto.
at 136,000 miles 2 idlers bearing were dry of grease. I had just purchased the truck
stydel311
Jan 31, 2014 01:30 PM
kennethpina
Dec 16, 2010 01:19 PM
trapperon
1997 - 2003 F150
Jan 24, 2007 09:35 AM
andy wick
Sep 28, 2005 02:43 PM
Snoopy1
May 7, 2004 08:55 AM
