Truck is throwing this code P2452 😑
Old Jun 16, 2017 | 09:19 PM
Bohen's Avatar
Bohen
Hopped in the rig went into the store to buy some came out and this code was thrown anybody experienced this is it something minor like a faulty sensor for perhaps I hope I'm still under warranty
Old Jun 17, 2017 | 04:49 AM
Just Strokin's Avatar
Just Strokin
Diesel Particulate Filter Pressure Offset Test
The DPFP Sensor is checked during after-run conditions (period where the key is turned off, however the ECU is still powered), to verify that the sensor has not drifted from the ambient with no exhaust flow. This test is performed by comparing the sensed pressure to a threshold (due the gauge sensor, this value should be 0)
Diesel Particulate Filter Pressure Sensor Offset Check
DTCs P2452 – DPFP Sensor Circuit "A"
Monitor Execution Afterrun
Monitor Sequence None.
Sensors OK DPFP Sensor
Typical Monitoring Duration 1 second.
Old Jun 17, 2017 | 08:23 AM
Bohen's Avatar
Bohen
Thank you for explaining this now,I have 3 questions . 1st one how do I fix this ? 2nd is this a common problem ? 3rd Should I reset the code and will it be fine Drive if the code does not reset or comes back temporarily for a few days until I can get it to the dealership since it is still under warranty ? Thanks and if you got kids Happy Father's Day
Joe/GA
6.7L Power Stroke Diesel
25
Apr 3, 2020 06:54 PM
larryk2005
Jun 23, 2018 11:49 AM
aphotic26
6.4L Power Stroke Diesel
18
Aug 30, 2013 05:15 PM
grndpndr2
Dec 2, 2010 12:35 PM
Fordfrog206
2004 - 2008 F150
Feb 14, 2008 10:29 PM
