Factory Sony sub
Old Jun 15, 2017 | 10:24 AM
Slavoise's Avatar
Slavoise
Factory Sony sub
The stock sub with the Sony system is a complete joke! Has anyone looked at the "factory plug in" kicker sub? Will it work with the Sony system? Is that sub any better?
Old Jun 15, 2017 | 10:34 AM
Shreve T's Avatar
Shreve T
Beginning to believe the whole Sony system is a joke !! No matter what i do i still cannot find the sweet spot where the system can take a little base..
The EQ is junk !!!
Old Jun 15, 2017 | 10:43 AM
Tricon's Avatar
Tricon
The Sony system is a complete joke. You can spend money trying to make it better, but I think you'll be disappointed no matter what you do.
I just went all out. Sounds amazing.
Old Jun 15, 2017 | 10:54 AM
Shreve T's Avatar
Shreve T
Did you replace the head unit or just the sup
Old Jun 15, 2017 | 11:23 AM
Tricon's Avatar
Tricon
Just added an amp and two subs. Made the box myself for about $40 in materials. Amp was $100 and I had the subs already. If I turn it all the way up on the bass **** it blurs my vision haha. Totally good for your ears I'm sure. Turn it all the way down and they are barely noticeable. One of my favorite upgrades so far, I really missed the low notes.
Old Jun 15, 2017 | 11:41 AM
Slavoise's Avatar
Slavoise
Did you have the Sony sub back there? Did you tap into the "speaker/sub" lines from that or run new audio cables?
Old Jun 15, 2017 | 11:42 AM
Shreve T's Avatar
Shreve T
Good deal !!! Thank you
Old Jun 15, 2017 | 12:01 PM
Tricon's Avatar
Tricon
No, I just ran a + and - from my rear left speaker runs in the rear driver kick plate to my amps high level inputs. Super easy install.
Old Jun 15, 2017 | 12:14 PM
Tricon's Avatar
Tricon
I would wire it like this even if you do have the stock sub. Playing around with it on my buddy's with the Sony system it seemed like the Sony eq lowered sub output when you cranked up the volume. Not sure if they did this by lowering voltage at the amp or more likely they were attenuating lower frequencies when the volume went up. You want your subs to have a full signal since they can handle it now lol.
Old Jun 15, 2017 | 12:31 PM
payne5757's Avatar
payne5757
If you are running a high level input, what are the RCAs in the pic?
Old Jun 15, 2017 | 12:51 PM
wfedwar's Avatar
wfedwar
I would think there is a high pass on the rears if you have a sub...
Old Jun 15, 2017 | 01:14 PM
Tricon's Avatar
Tricon
Those are the high levels, the amp includes RCA's that end in a stripped wire. The amp figures out if it's a high or low level input automagically.
Old Jun 15, 2017 | 01:15 PM
Tricon's Avatar
Tricon
That would be something to check out! I don't have the Sony system, I get the full signal in the rear.
Turbo Dog
May 20, 2015 04:59 PM
des929
2009 - 2014 F150
Oct 12, 2009 10:44 PM
B10K71
Sep 10, 2008 04:34 PM
sandaholics
Jun 25, 2008 05:06 PM
