Curious who runs a axle that may have been pitted from sitting out in the elements. I have this one, which is good, but one side is pitted all the way across.
Like Ross said, not a problem. A few days in an electrolysis tank would remove that rust. OTOH, removing as much rust as possible with a wire wheel, a couple coats of Ospho followed with good paint would do the job of stopping the rust.
Forging scale? I've never seen that before to be honest. Not saying it doesn't exist but I've never seen it. My other 2 axles are smooth on both sides, I think anyway.
Yes, but it happens infrequently when the metal isn't properly cleaned before coating. Not saying that's what it is, just that it looks like it to me. I have seen pitting from corrosion (electrolysis), and pitting from the redox reaction of iron and oxygen.
Ford always used good steel, especially their axles. There's an amazing photo in one of the Ford books of an axle twisted like a pretzel without breaking.
Try convincing anyone up here that owned a Ford in the 70's...lol
If your axle came from the rust belt the back side usually rusts more than the front. The front gets blasted by road debris but the back side collects all the crud. This is particularly true on vehicles used on dirt roads where they use calcium chloride for dust control in the summer.
I wire brushed mine then used Eastwood rust converter and then aluminum paint. I didn't like the aluminum look so I covered that with Rustoleum 2X gloss black.
