Trailer disconnected.... I'm not towing
Old Jun 14, 2017 | 07:57 PM
2006fordf25060's Avatar
2006fordf25060
Hello, tonight the weirdest thing happened, I was running up to the store (not towing anything, haven't for at least a month) and the trailer disconnected alarm went off and the trailer brake controller cane on. Doesn't change anything on the truck just super annoying. What could I do to fix this? Faulty connection somewhere?
Old Jun 14, 2017 | 08:24 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here is a thread with some discussion on this problem. I think there are some links and a few voltage checks in there somewhere. May be of some help. I believe the TBC can report fault codes also. A basic code reader won't see them as they are manufacturer specific. A professional scanner should report TCB codes if there are any. You can have stored codes without a check engine or wrench light on.
https://www.ford-trucks.com/forums/9...ml#post9193806
Old Jun 14, 2017 | 10:40 PM
Yahiko's Avatar
Yahiko
First thing. Go to the back bumper and take the back plug off the trailer
7-way connector and look for green fuzz. If you find that more than likely
you have also found the problem. Clean with contact cleaner and then
reassemble it with dielectric grease in the connector.
Old Jun 15, 2017 | 01:00 PM
High_HP's Avatar
High_HP
Sounds like a bad ground or short...they become evident when u hit a bump...then the warning message/chime is triggered.
Old Jun 15, 2017 | 06:59 PM
2006fordf25060
Thank you all for the feedback. The trailer we haul doesn't have trailer brakes so we just pulled a fuse and that has solved the problem for now.
DirtRacer96m
Aug 19, 2018 08:18 AM
Don Schuler
Jan 17, 2018 11:28 PM
JoshC017
Nov 16, 2016 01:01 PM
superduty steve
Mar 27, 2016 08:23 PM
mrw1
Jan 1, 2012 06:11 PM
