Sponsored by: Real Truck
TBC Fault Code need help
Old Jan 1, 2012 | 05:08 PM
mrw1's Avatar
mrw1
I have read all the posts on TBC fault codes. I have a 2006 with the ndredded TBC Fault- TBC fault at start up, and when operating the brake controller manually. The TBC fault comes on with or without a trailer hooked up and even if the controller is unplugged(behind the controller in the dash). The brakes and trailer lights all work fine (using the controller). I was getting the annoying beeping and trailer disconnected message. I cleaned all the contacts and the beeping occurred less but did not go away. To see if the problem was a ground problem I hooked my jumper cables up to the frame of the trailer and the frame of the truck... no more trailer disconnected and beeping. Now that I know what to do about the beeping, I need to figure out the TBC fault. I have read every post on the subject and I do not know where the fault codes are stored or how to clear them. Since the controller is working fine with the exception of the fault code shown on the dash, I do not know if I need a new controller or just have the codes cleared. Any suggestions?
Old Jan 1, 2012 | 06:11 PM
carltonwebb's Avatar
carltonwebb
I had one at work doing that exact same thing. Fault at startup with no trailer connected. It was the controller itself. Not hard to change but I cannot remember the cost. Something about the internal self check goes bad with them and causes that error message.
BPofMD
All Things Towing
23
Sep 29, 2018 04:36 PM
2006fordf25060
Jun 15, 2017 06:59 PM
Tattie Tam
May 25, 2011 07:37 AM
bkvanbek
Apr 20, 2007 06:04 PM
JaysRanger
All Things Towing
Aug 3, 2005 10:02 AM
