Sponsored by: Real Truck
Brake light problems
Old Jun 13, 2017 | 03:24 PM
las vegas towing's Avatar
las vegas towing
I have a 2007 F450 Super Duty. The brake lights work but when I turn on the headlights the brake lights do not work. I've changed the light switch on the dash, replaced the pig tail under the dash and replaced the break light sensor that mounts up by the emergency brake assembly under the dash. Nothing has fixed the problem. Im starting to think it may be the break relay but don't want to spend any more money on parts that I don't need. Any suggestions??
Old Jun 13, 2017 | 04:03 PM
projectSHO89's Avatar
projectSHO89
There's no such thing as a "break relay".
Go check the ground for the tail light assemblies. Sounds like its open. It's up under the bed in the left rear corner on the frame rail behind the bumper.
Old Jun 14, 2017 | 10:43 AM
ccerniglia's Avatar
ccerniglia
are there dual filament bulbs installed in the rear? All these parts you threw at the truck, did you check or replace the bulbs?
texasweldingco
Feb 13, 2019 05:22 AM
Ex-Jermin
Oct 28, 2016 01:08 PM
BFTUFF
1997 - 2003 F150
Jul 5, 2012 09:34 PM
Daviddc114
Mar 26, 2011 09:38 AM
2ndmouse
May 10, 2004 08:38 PM
