2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Hesitation before accelerating
Old Jun 13, 2017 | 12:12 PM
dsamuels's Avatar
dsamuels
When I'm on the highway and push the accelerator down quickly, there's a significant delay in the transmission speeding up the car.
What gives?
Old Jun 14, 2017 | 03:02 PM
Fmc4lfe's Avatar
Fmc4lfe
Maybe lag, these ecoboost respond better to just rolling into the throttle. No need to floor it like old school v8 trucks all your power is down low.
Old Jun 14, 2017 | 09:55 PM
ad2435's Avatar
ad2435
I have a 15 for 2.5 years and never was really happy with how the tranny responds. Too much herky jerky. I also back into my driveway and there is always a delay from drive to reverse when the pedal is pressed while in reverse. There is tons of power no doubt but some of the software decisions that the transmission makes is frustrating.
Old Jun 15, 2017 | 12:45 PM
glockholiday's Avatar
glockholiday
I always drive mine in tow haul mode. Way better response at all times. The trans is definitely programmed to be soft and smooth, a little too much for most of our tastes.
Old Jun 15, 2017 | 07:31 PM
Fmc4lfe's Avatar
Fmc4lfe
Also run 93 octane crazy difference, all we run in our eco trucks and new navi
Old Jun 16, 2017 | 04:56 PM
glockholiday
Tried 91 a couple times instead of 87, no noticeable change for me in drive-ability or mileage. Manual says 87, that's all it needs.
Old Jul 16, 2017 | 02:01 PM
rbushnell52's Avatar
rbushnell52
I have a 2015 Expo Plat 2wd, had the same hesitation problem, my ford garage reprogrammed the pcm and problem went away. At the same time fixed another problem....when accelerating to enter interstate would hear a bunch of clicking noises and a cloud of carbon would come out back. After reprogramming pcm that stopped as well. Fuel mixture wasn't right. From what I've read you should get pcm reprogrammed every once in awhile cause Ford is always changing the programming.
Old Jul 16, 2017 | 10:39 PM
johnkn's Avatar
johnkn
Easy fix. Here's the EZ button:
Throttle Calibration
Throttle calibration can substantially improve throttle responsiveness over "factory standard." Many people notice what appears to be sluggish throttle response or a "dead area" at initial accelerator depression. Throttle calibration can take care of these.
1) turn the key in the ON position (don't start the engine)
2) press the gas pedal down slowly all the way down
3) let go of the gas pedal fast so it come back up
4) turn key into the OFF position
repeat steps 1-4 two more times then start engine.
Most drivers notice an immediate change in throttle response, but depending on your driving style, you may need to repeat this procedure periodically due to the computer's adaptive programming. You likely need to repeat this procedure any time the battery is disconnected.
CampSpringsJohn
20
Oct 24, 2016 03:31 PM
idiguy111245
Oct 8, 2013 04:07 PM
oldhalftons
1947 and Older Ford Trucks
Sep 10, 2005 05:19 PM
