Popping while backing in sharp?
Old Jun 13, 2017 | 12:20 AM
Nbing's Avatar
Nbing
I've been reading numerous other posts about noises and problems with the automatic locking hubs on the 93's. I just wanted some other views on what the problem could possibly be before I throw down some cash into this issue.
The Truck:
1993 F-250 Super-Cab 460 7.5l 4x4
The History:
Purchased the truck from the second owner. The first owners must have worked the hell out of it (i.e. light bar installs, fifth wheel conversion, cb's, and some careless conversions). The truck is lifted with blocks in the back under the leaf springs. When I purchased the truck the steering was extremely loose, and the steering wheel wasn't aligned correctly. When I took the truck in I noted that there was popping whenever backing in sharply and turning the wheel to the right, same goes for sharp turns when going forward. I took it into the dealership because they're the only one that had a lift that could fit it, they said the alignment was perfect but needed a new power steering gear box and cam slugs. Much money later, I got it back, drove it home, and while backing it into the driveway, I cranked the wheel, it popped so I loosened up the turn and then the engine cut and died. Few weeks later, there is constant popping when doing sharp turns and the risk of the engine dying (although it happens rarely).
What I've done:
Besides all the reading I've done on the issue I just cannot pin point it down to one thing, I've looked at the U-joints and checked if the hubs were locked. I jacked up the truck, spun the wheels, and they each moved freely without the driveshaft moving. I was about to order the conversion from automatic to manual but would like to know for sure they're the hubs. As far as the cutting out problem, I'm pretty sure its just the pressure switch(?) on the gearbox as what the mechanic told me at ford.
Can anyone guide me for more tests I can perform to figure out this issue?
Thank you in advance!!
Old Jun 13, 2017 | 10:12 AM
Redark1's Avatar
Redark1
check the bolts where the radius arms bolt on. make sure there tight.
Old Jun 13, 2017 | 11:32 AM
Nothing Special's Avatar
Nothing Special
Originally Posted by Nbing
.... The truck is lifted with blocks in the back under the leaf springs....
That could be stock. 4WD F-250s and F-350s of this era had lift blocks above the rear axle from the factory. Not saying yours wasn't lifted farther, but blocks are to be expected.
On the hubs, if they are disengaging (and from what you say, they are) then going to manual hubs probably won't change anything (except give you more confidence that the hubs are doing what you want). It might still be worth doing, but I doubt it will fix the popping.
Old Jun 13, 2017 | 04:31 PM
Nbing's Avatar
Nbing
Here's a picture of the truck so you guys got an idea of what I'm working with. Checked the radius arms in the front and everything seems tight, same with the ball joints, and no rubbing on the wheel wells.
Old Jun 13, 2017 | 10:17 PM
'89F2urd's Avatar
'89F2urd
Damn, I like that thing.
Check your beam pivot bushings and spring bushings. Have someone move the wheel back and forth (rapidly back and forth, not turning the wheel one way then the other) while you look at all of the components.
Old Jul 18, 2017 | 11:54 AM
Nbing's Avatar
Nbing
Welp, sometimes the things you think are the most complicated are the simplest.... Turns out there is a faint spot on the drivers leaf spring that the wheel rubs against when backing in. Stumped the Ford techs and me lol, took my dad 5 minutes.
Ive gotten new cam slugs and an alignment recently, does anyone know a course of action from here? Or is smaller tires the only resolution to the problem.
Nbing
Old Jul 18, 2017 | 09:49 PM
Nothing Special
Don't turn so sharp?
Seriously, the driver's front 33 on my Bronco rubs the radius arm REALLY bad in a sharp left turn. I just don't make left turns that sharp. Problem solved.
Old Jul 19, 2017 | 03:43 PM
'89F2urd's Avatar
'89F2urd
Lol + 7 characters.
rucker007
Dec 29, 2014 07:24 AM
akuhr93'f150
Apr 1, 2012 10:26 PM
thepodpiper
Offroad & 4x4
21
Feb 10, 2012 04:25 PM
M88
Sep 3, 2010 07:40 PM
Don
1978 - 1996 Big Bronco
Jan 5, 2000 04:37 PM
