302 board 30 over
Old Jun 12, 2017 | 04:55 PM
Ghost42's Avatar
Ghost42
302 board 30 over
So i decided to build a motor for the first time for my 94 F150 Flareside. I bought a old 302 with low miles (70k), Stock crack, rods, and I decided to go forged pistons (30 over) only because my block needed to be board out do to rust. I have GT40 heads with 1.6 trick flow roller rockers,and a E303 cam. I was told I should have got a 351w. BUT... ITS TO LATE.. I want to run a B@M blower or a single or twin turbo set up. 5-9lbs of boost.. any suggestions?
Old Jun 12, 2017 | 09:22 PM
Blurry94's Avatar
Blurry94
If this is an automatic transmission and you're set on the cam, then you will need a higher stall converter...AND an adjustable fuel pressure regulator and likely aftermarket tuning.
jbanderson
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 26, 2017 07:50 PM
The Confederate
17
Mar 29, 2012 03:34 PM
papabills54
29
Feb 12, 2007 11:14 AM
WrenchHead84
Jan 15, 2005 04:32 PM
chitown65
28
Jun 28, 2004 09:25 PM
