emergency flasher switch
Old Jun 12, 2017 | 08:52 AM
teamo's Avatar
teamo
1967 f250. When I removed my emergency flasher switch from the glove box it fell apart. I have all of the pieces and I can put it back together but I'm not sure I have the copper contacts right. When I test it with an ohmmeter in the on position all four of the poles have continuity between them. In the off position all of the poles are isolated from each other. Is this correct or should it be two poles connecting with the other two poles?
Old Jun 12, 2017 | 02:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by teamo
1967 F250: When I removed my emergency flasher switch from the glove box it fell apart.
C6AZ-13A350-D .. 4 Way Emergency Flasher Switch / Obsolete
1966 Galaxie/LTD/Falcon/Fairlane/Mustang from production date 3/1/1966.
1967 F100/350; 1968/69 F100/350 without factory installed integral A/C
MILLS MOTOR CO. in Fairfield MT has 1 = 406-467-2511.
MUSTANG'S ETC. in Van Nuys CA has 6 = 818-787-7634.
Old Jun 12, 2017 | 03:03 PM
JEFFFAFA's Avatar
JEFFFAFA
Circuit 2A and 3A lead to the park lamps. 810A leads to the taillamps eventually. 385 is power in from the flasher. So all 4 terminals should be connected to flash the front and rear lamps.
Old Jun 12, 2017 | 03:25 PM
teamo's Avatar
teamo
That's what I was looking for. Looks like I should be able to repair the switch. Thanks for the help.
braol
Jul 11, 2018 07:52 AM
ehbedard
18
Sep 16, 2015 09:06 PM
eminencefront
Oct 1, 2014 10:28 AM
teched
Jul 27, 2014 11:18 AM
zombiesawyer
Jul 12, 2009 07:52 PM
