So the speedometer in my 1949 F1 has never registered the correct speed. It hasn't been a big concern considering how I drive it but lately have thought I would like to correct it if I could figure out the problem. It works smoothly but to get the correct speed I have to multiply the shown speed by 1.42.
So when it shows 32 mph it really is going 45; 39mph =55 and 42mph =60.
Any ideas?
Thanks, Brian
Is the drivetrain stock? That's a HUGE correction. I switched from 3.92 to 3.50 gears and only have to do about a 10% correction. There must be something inside the speedo that is causing your calibration to be so far off. Even if the trans had been swapped from a bigger truck with steeper gears (do you have a spur-gear 4-sp?) that truck would have been near 6:1 gears to make such a difference.
All that is good. The cable and needle work smoothly. My thought has been that it has to do with calibration though I have never heard that they can be calibrated or that possibly the gear at the end of the cable that goes into the trans has the incorrect number of teeth?
Ross,
I have thought of that and will do that the next time I am laying under the truck....another reason why I need to raise the ceiling in the shop and install a lift!
But then I thought , maybe incorrectly, that if what I have was the wrong number of teeth then they wouldn't mesh?
For one drive gear (the worm gear on the trans) there were 2 or maybe 3 driven gears available. If you change the drive gear, then there are 2 or 3 more options. But yours is so far off I can't imagine it's the wrong gears. Unless you have the HD 3-sp?
With that big of a differance it sounds more a differential gear ratio. Think about it, there aren't that many components. My F3 I changed the driven gear down one tooth to accommodate the 16" tires vesus the 17" stock and it came out just fine. I doubt it has anything to do with the speedometer itself.
I have 750/16 on my F-2 and it knocks my speedo off by about that much. I rarely pay attention to the speedo anyways, it always seems everyone else is flying by while I'm enjoying the drive.
